Old 09-06-2024, 09:01 AM   #1
Lenior , North Carolina
What’s it worth. 1964 Ambassador
Hello, I’m looking at this trailer and need some reference to its value. It looks to be original and perhaps in average condition for its age. Under carport and not moved in 6 years, also the fresh water tank has been removed.
Thanks for your input.
ID:	447159   Click image for larger version
ID:	447161   Click image for larger version
Jimbo614 is offline   Reply With Quote
Old 09-06-2024, 09:27 AM   #2
2023 28' International
Mercer County , New Jersey
A quick google search showed values ranging from $18,000 for one that seems better to $7000 for one that was worse.
Here is an older article (so adjust the pricing as needed) on what goes into condition and pricing: https://vintageairstream.com/airstream-price-guide/
jeffb831 is offline   Reply With Quote
Old 09-06-2024, 12:35 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
RE: What's it worth? 1964 Ambassador
Greetings Jimbo614! Welcome to the Forums and the world of Vintage Airstreams!
Before trying to attach a value, I would suggest getting confirmation of the actual model year. The type of upper cabinets, the color of the stain on the cabinets, and the type of windows next to the door all tell me that this trailer is more likely to be at least a 1965 or possibly a 1966 to 1968. A 1964 Ambassador would have jalousie windows next to the entry door, and in all probability would have golden oak woodwork. Rather than the separate range and oven, it would more likely have a four burner range/oven combination. While it is possible for there to be mistakes on titles, if you are in a strict title state, and there are any discrepancies between the trailer ant the title that the owner has, your issues with registering the trailer could be significant. I know in Illinois, I had an issue because someone in Missouri had changed a letter I to a number 1 and I had to go through a process when I transferred that trailer's title to my name because of that discrepancy.
Provided the trailer is in sound condition both interior and exterior, with a title that matches its serial number, I would suspect that it would be valued at between $8,000 and $12,000 depending upon the ages of expensive replacement items such as axles (if more than 15 years old), water heater (if original or more than 15 years old), furnace (if original International Oil Burner Corporation model), Dometic 2-Way Refrigerator (if original or more than 15 years old) -- each of these items can cost upwards of $1,000 or more, particularly if you must have them changed out by a shop. The water tank is mounted above floor under one of the center beds if a twin model or under the pull-out bed if a double bed model -- as a basic rectangular tank, it is basic, and quite reasonably priced as a generic -- I believe that mine was sourced through Inca Plastics (this was for 1964 Overlander -- I am not absolutely certain whether the same would apply to the post 1964 models as I am fairly certain that the trailer in question must have been produced post 1964).
Good luck with your investigation!
Kevin
A 1964 Ambassador is going to look very similar to my 1964 Overlander Land Yacht International -- Note that next to the door it has two stacked jalousie windows -- the Ambassador as well as all longer Airstreams from 1964 shared this feature. Also, the 1964 Ambassador would have a Door-Within-A-Door while the later models would have a separate screen door with a solid entry door. The Ambassador would be about 2-feet longer than my trailer.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
What is my 1972 Ambassador worth?? Shellybob9 Member Introductions 1 09-14-2019 06:49 PM
What is it worth 1964 globetrotter Hardworking 1960 - 1964 Globetrotter 17 09-07-2014 01:45 PM
1964 Globe Trotter :: 1964 Airstream Globe Trotter Wilcu Airstream Registry Discussions 1 03-11-2012 04:35 PM
Good deal? Worth restoring - 1964 Safari Sportyj Trailer Values 12 02-06-2012 09:25 PM
1979 28ft Ambassador (what's it worth?) timmy Trailer Values 8 03-14-2011 05:29 PM
