09-29-2024, 02:54 PM
2021 30' Flying Cloud
Sioux Falls
, South Dakota
Update or hold out?
As you probably know, Jo Ann and I are going to trade our current SOB for an Airstream very soon. The search parameters are: 2005-2015 30' or longer, rear queen bed, two air conditioners, and at a dealer's lot. I've been searching rvtrader and there are a couple that are interesting. One is very close to us, but the price seems a bit high and there are no pictures. There is a twin to it at PPL that has been there for some time, currently priced at $58,000. The one in Wentzville is quite a bit more than that. Both of these meet all of the criteria.
There are two more that come close, and both are less money. PPL has a 31' but only one a/c. There is another Classic 30' about 3 hours away, again only one a/c.
We're going to go big on solar, so there will be electrical upgrades anyway. Would it be worth it to take one of the lower priced trailers and add the second a/c, or should we stick with the requirement of two air conditioners? The advantage of doing the upgrade is that at least one air conditioner would be new.
Thoughts? Suggestions?
David Lininger, kb0zke
7490
2021 Flying Cloud 30 RBQ
09-29-2024, 03:40 PM
1973 21' Globetrotter
Houston
Seems like we are always working on these trailers anyway. Having upgraded my '73 that had the riveted on AC to a modern one, I would say it isn't a big deal, and if it were me, I would go for it. All that being said, it would be interesting to know if there are AC wires run to the "missing" AC spot, so that wiring would already be in place.
good luck!
09-29-2024, 04:05 PM
19’ Bambi Flying Cloud
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia
, Husqvarnia
It sounds like a/c is a high priority for you. With your requirements, I’d want to make sure the trailers in question have ducted a/c, and I’d want to understand how difficult it is to tie into that if one of them needed a second a/c unit added. Ducted a/c is a major upgrade over earlier units with the drop-ins.
2017 Bambi 19 Flying Cloud
09-29-2024, 05:20 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
It it was me I would wait to get one with two A/C's since that is so important to you. Cutting holes in the roof gives me pause.
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
09-29-2024, 06:36 PM
Sioux Falls
, South Dakota
Good points! Thanks. Since everything we're looking at happens to be a Classic, I'll ask on that part of the forum. My guess is that the wiring is probably already there for the second a/c, and it is probably a direct drop-in in the bedroom.
Our old Foretravel didn't have ducted a/c, and this trailer does. The original a/c units on the Foretravel were very quiet compared to the new ones. This is almost as loud as the new units on the Foretravel, so I'm not sure how much the ducting helps in that regard. Of course, this isn't an Airstream...<grin>
I also haven't seen any of these trailers in person, just pictures of most of them. Sure wish Bill Thomas would get the pics up of that 2013 Classic. We may just have to take a few hours and drive over there.
7490
09-29-2024, 07:33 PM
2010 30' Classic
Warren
, Manitoba
The second A/C takes the place of the vent in the bedroom. Our new to us 2010 Classic Limited has the 2 A/C units, and I am still not certain that I like this set up. Our 1994 34 had MaxxAir 10 speed with remote fans in the front living area and the rear bedroom. They could be set to pull air in at one end and out at the other. At night it was great to set the bedroom fan "in" at the lowest speed and you get a tiny breeze and virtually silence. We miss that with the 2 A/C units. It seems easier to keep a lower temp in the trailer with the 2 fans unless it is extremely hot ( over 100 degrees).One other thing when looking at units that became a "no buy" for us was the shower location. I refused to have the shower door open onto the toilet. For us it has to open into the hallway. Much easier to enter and exit the shower, and it seemed to have more room. With 2 A/C units you have to have a 50 amp service panel, and it will be much easier to buy one with that in place, as well as the A/C units. We installed 2 new 15000 BTU A/C units with heat pumps in this trailer. We have had the twin beds in previous units, and it is taking some time to get comfortable with the queen. We miss the floor area for dressing and the extra space that twin beds give. Also miss the exterior storage. As a hint, try getting in and out of the shower whichever unit you look at. JMHO!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
09-29-2024, 09:51 PM
1994 25' Excella
Waukesha
, Wisconsin
If the second a/c is important to you, then buy a trailer with two a/c from the factory. There is no easy way to properly add a second a/c to a one-a/c trailer. With only one a/c from the factory the 120v electrical is only 30 amps, but on a two-a/c trailer it's 50 amps.
You can't just stick a second a/c on the roof and wire it in on a 30-amp trailer. This job will involve figuring out how to run power to it since there is not enough capacity in the 30-amp system.
Aside from that, I'm curious why the desire to stick to trailers on dealer lots? Lots of great trailers out there being privately sold so I think you're needlessly limiting the market for yourself. There are risks to buying privately, but in my experience there are equal risks to buying from dealers. The difference is that dealers are better at cleaning things up so you don't see the problems.
For much less than the increased cost at a dealer you can arrange to have a private inspector check out any trailer you are considering buying from a private seller.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
09-30-2024, 08:20 AM
Tampa
If you want a second A/C, get it installed. Remember, besides another A/C it's also 50 amp service, which is a big deal.
Besides, shopping is half the fun.
09-30-2024, 08:39 AM
1994 30' Excella
alexandria
, Kentucky
I would get the trailer with the factory 2nd A/C unit. Not only is there an electrical upgrade there is also a condensate drain line to be considered.
I would have put one in years ago but this is a very involved job.
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
09-30-2024, 09:09 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Up in "snow country", the prices are just going to drop for the next few months. Very few folks are thinking about buying an RV when there's snow on the ground.
Will that be reflected in the "list price" shown on a dealer's web site? Maybe not. There are a lot of dealers who really don't tell you the "real price" until they are pretty sure you are interested. It's a good bet that all the prices you see right now are at least 10% over the "real price". Come February ..... maybe they are 20% .... maybe more ....
09-30-2024, 09:40 AM
2011 31' Classic
Nellysford
, Virginia
David, you probably already know about RVTRADER.com. We bought all three of our 30s from that site. Easy to filter for what you want. Recommended. ~GH
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
10-01-2024, 06:22 PM
Sioux Falls
, South Dakota
Silver Otter, I'm very familiar with rvtrader.com. That's my primary search site. There are two seemingly identical trailers with price difference of more than $11,000. That sort of information is huge.
We've pretty well settled on a 2010-2013 30' Classic RBQ with two air conditioners (which includes the 50A service). I search 2005-2015, but there are things that show up in 2014 and 2015 that I don't care for, with only one (ducted a/c) showing up in 2015.
7490
10-06-2024, 12:39 PM
1998 31' Excella 1000
Simpsonville
, South Carolina
Very easy to add another air conditioner to a rear queen or twin. PM me and I'll tell you how.
Ken
10-06-2024, 06:51 PM
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN
, Nebraska
David: re search for 30’ airstream
c.
David:
I know you said you wanted to buy from a dealer, however, we are located in Lincoln, NE, not that far away. We have a extremely clean 2014 30’ Flying Cloud rear queen with twin factory recliners, upgraded blinds, 100 watt solar, upgrade ultra leather in kitchen dinette and recliners, 3” lifters, rear camera and monitor, two ACs with one having EasyStart, BlueOx hitch and stabilizers and all of the standard features found on the Flying Cloud. Tires are in great shape and overall the trailer is in immaculate condition. This is stored indoors when not in use.
We are currently at the int’l Airstream Rally in Sadalia, MO but will be home on 10/12/24. My wife and I have moved into senior living 3 months ago and would like to down size. Call me if interested; I could deliver if necessary.
402-570-6829. Larry & Marcia Link 420 So 47th St Unit 227, Lincoln, NE 68510
10-06-2024, 06:56 PM
Link’s Travels
2002 25' Safari
LINCOLN
, Nebraska
David:
10-13-2024, 07:08 PM
Sioux Falls
, South Dakota
Thanks, everyone, for your thoughtful suggestions and ideas. We're going to look at a 2013 Classic 30 on Wednesday. The only thing that isn't to our "spec" is the power awning on it instead of the manual one. Of course, descriptions and pictures on the computer don't tell the whole story, so we'll know more later this week.
7490
