Old 08-09-2017, 11:05 AM   #1
1999 25' Safari
Sparks , Nevada
Heartbroken - Rear floor rot
Hello all
I just found out that my much loved and upgraded 1999 Safari Six Sleeper has the much dreaded rear floor rot. I have taken it to a local RV repair shop here in Reno, NV that has done some of this type of work before and was told that the cost to fix would be $7k to $10k. I simply can not afford that and I do not have a building to work in to fix it myself. So I would very much appreciate help in coming up with a value (as is) and suggestions on how to sell my baby. Baby has over $5k in upgrades such as Led lights, 3 stage converter, small fold out table, spare tire carrier, rear hitch for bikes, bathroom door extension, HDTV antenna upgrade, Dual battery setup w/ marine switch and 2 lifeline batteries - aluminum steps - and very much more. I thought that I had about 5 more years left in my ability to airstream but it seems that I just can't.
Vic H
ID:	291729   Click image for larger version
ID:	291731   Click image for larger version
Vich is offline   Reply With Quote
Old 08-09-2017, 11:13 AM   #2
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
You might try for a few more quotes before you decide to sale. Depending on the severity of the rot it is possible to just replace the rear section.
1973Argosy is offline   Reply With Quote
Old 08-09-2017, 11:14 AM   #3
nickclifford's Avatar
1972 31' Sovereign
felton , California
RV repair shops charge around $120.00+/ hr ? Crazy prices for those on a modest income or other expenses like having kids ! I'd look around for an independent guy without the huge overhead of an RV place ... you maybe able shave a few thousand off that price ? good luck.
It's quite sickening that AS made these trailers with such poor design and lack of thought for inevitable leaks and how easily the flooring could rot out, why didn't they use a sealant on the wood floors?? Maybe I'm missing something here, I don't get it ?!
nickclifford is offline   Reply With Quote
Old 08-09-2017, 11:49 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Unless you are doing a shell off repair. Why would you need a building?
How bad is the floor rot? How big an area?
Old 08-09-2017, 11:49 AM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yes, look around and at least get another estimate.
Perhaps an insurance claim?
I am not beating up on anyone, but.... while not the perfect design a little simple preventive maintenance of this well known issue prevents this problem.
We can't just camp in them and then park them.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-09-2017, 12:13 PM   #6
1999 25' Safari
Sparks , Nevada
It seems to be rotten for about 14 inches. It would require removing the shower, bed and maybe the black tank et al. Also have to remove belly pan and rear banana wraps to get to the bolts. If I can do just 2 feet of floor then I would need to weld in added cross framing to attach to. We only have 2 temperatures here, below freezing and above 95F. I fear that as soon as I drop the belly pan the mice will find a new home.
I did reseal many places, but never thought to do the rear area that airstream never found a need to do in the first place until I found it here on Air Forms.
Old 08-09-2017, 12:50 PM   #7
funkill's Avatar
Tucson , AZ
Images: 27
Just curious - who did you find locally with experience in this repair?
I just got my 1973 back from Sierra Restorations in Grass Valley for this very same repair (and more). They did superior work - and while it was expensive, I still think it was fair. I'd like to find someone local that I can use for some of the on-going, but less extensive work. I am not excited about the idea of towing over the Sierra's yet (had it towed by Sierra Resto previously).
Thanks and sorry you're having to consider selling. I've heard lots of folks just continuing to use their trailers, with the floor rot/rear end separation, for years without any "significant" changes. Mine was likely rotted for 10+ yrs.
Funkee
funkill is offline   Reply With Quote
Old 08-09-2017, 01:13 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Rear hitch for bikes might be the cause of the problem
Old 08-09-2017, 02:01 PM   #9
1999 25' Safari
Sparks , Nevada
Rear hitch has never been used. I had it installed but never got around to using it at all.
Old 08-09-2017, 02:05 PM   #10
1999 25' Safari
Sparks , Nevada
Funkee
Paramount RV in Reno. Can you tell me how much Sierra Restorations set you back?
Old 08-09-2017, 03:15 PM   #11
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
This is no doubt a major job and would take someone with prior experience doing this job to get it done in a reasonable time without having to learn as they go.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-09-2017, 03:16 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If you sell the trailer now you loose the use of it and the upgrades. My suggestion is first find the water leak and repair it. Then I would consider doing or having done a partial floor replacement from the top. I would "elephant ear" the new pieces into the C channel. Or have someone do it. The replacement floor can be in pieces. You do not need to have the joints on a frame. All you really need is something you can walk on where you can walk one that covers the frame. The belly pan does not need to come off for this type of repair and the interior walls stay on. You would be depending on the original bolts not to br totally rusted through. I would take pictures along the way to be able to show a buyer later what was done. Doing this should buy you another 5 years and then it can be dealt with more properly when some one wants to. The tanks are below the floor so will not be disturbed.
First fix thr leak and take up the floor covering over the affected area and dry it out. Then determine the extent of the damage.
I would not know how to price it with the damage. I have 2 that I have replaced parts of the OSB floor in and the work fine. But fixing the leak and running a heater on it and scooping out the mess that he OSB turns to is critical.
Old 08-09-2017, 03:22 PM   #13
funkill's Avatar
Tucson , AZ
Images: 27
The price was comparable to what you've been quoted. Mine was more like 30" of rot - and required frame repairs too. I chose to have a multitude of other unrelated items addressed: addition of grey tank, PEX throughout, new pump and water heater, sealing entire trailer, door adjustment, and more.....
Thanks for the recommendation for Paramount. I've heard good things but did not know they had in-depth experience with Airstreams.
Funkee
FunKee - and the Silver Olive
2006 F-150 Lariat QuadCrew
AIR 31804
WBCCI 10718
Old 08-09-2017, 05:45 PM   #14
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I have that same model. Reseal across the back and continue using. There is little weight on the back floor, it'll stay together another 5 years easy. For an easy fix open the back of the belly pan, you can get at the last few feet of floor, cut out the rotted wood and piece in a new piece then overlap a second piece for support. Just an afternoons job and done. Remember it's just a trailer.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-09-2017, 06:27 PM   #15
CRH
1995 25' Excella
xxxxx , xxxxxx
I agree, especially if you only plan to use it 5 more years. Seal the leak, pull up, some flooring, put a street sign over the weak spot, put back down the flooring and camp on.
CRH is offline   Reply With Quote
Old 08-09-2017, 07:26 PM   #16
1981 31' Excella II
New Market , Alabama
How about some photos? The trailer looks well taken care of. The main issue is it the attach points and rear hold down plate are intact. Pull up some carpet back there. Also open the rear compartment and see what the cross member looks like. REMOVE THE BIKE CARRIER NOW. It will just make things worse. Don't panic yet. Don't get taken advantage of. Having a rear bedroom helps but since you have a queen back there it maybe a little harder to remove that stuff. Removing the center belly skin will tell a lot about what is going on. I am sure the rear plate that holds the storage compartment door is leaking. You will need to remove the belly trim to get to that caulk joint that leaks and causes floor and frame rot. If you remove belly skin, pull out all old insulation and leave it that way.
At least you are in a dry part of the country. Where did the trailer come from?
Perry
Old 08-09-2017, 07:57 PM   #17
1999 25' Safari
Sparks , Nevada
Perry - This is a 6 sleeper with corner bed and shower in the back.
ID:	291783   Click image for larger version
Old 08-09-2017, 09:42 PM   #18
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I had the same floor plan and the same leak on my 2008 25SS. Cost to repair was $6k. I used timeless travel trailers in Denver - not sure I would have trusted anyone else. It's a massive job to fix the issue correctly which includes removing a lot of the interior and subfloor.
Most of the time the rear corner shower gets damaged (cracked) upon removal which is another $2k in expense as you need to order from airstream. Fortunately timeless were able to remove / reinstall my shower without issue.
If you leave as is just know that there are mold spores in the plywood at this point and covering them up does not solve the problem nor does it prevent the shower from falling through the rotten sub floor.
You could fix it yourself if you were very patient, mechanically inclined, had a good helper and had many many man hours on your hands to devote to the job. I opted to pay professionals who restore trailer's for a living. In the end I'm glad I corrected the issue "properly" as I ended up selling the trailer - and was able to sell with confidence knowing the trailer was better than new from the factory.
ID:	291801   Click image for larger version
ID:	291803   Click image for larger version
wulfraat is online now   Reply With Quote
Old 08-09-2017, 10:27 PM   #19
1972 31' Sovereign
felton , California
Great advice, "it's just a trailer' ! If it's not considered dangerous to tow, patch it up and enjoy the airstream for a while longer, no reason to panic & sell unless falling to pieces. I found a few minor areas of water damage, nothing structural, they're patched up and everything is fine. If I keep those areas dry, it would last like this another 50 yrs ..
Old 08-09-2017, 10:31 PM   #20
1972 31' Sovereign
felton , California
Regards,
JD
I agree Jeff, a little "preventative maintenance" from AIRSTREAM ! by sealing the wood would have made a huge difference! I think for a period, they even used particle board for flooring ? what a disgrace ... not cool !
Just heartbroken Goal15 The Pet Forum 29 01-05-2016 11:08 AM
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 01:07 PM
rear floor rot robertel Repairing/Replacing Floor &/or Frame 8 09-26-2010 06:46 PM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
