Old 01-03-2020, 02:42 PM   #1
Bulverde , TX
Twin bed support and airflow mod
Built raised twin bed platforms to add support to the “ledges” and to increase airflow between the mattresses and the colder storage areas.
We’ve slept on the them the past two weeks and the difference is significant. No more condensation under the mattresses (several nights we got into the 20s) and we slept so much better with the extra support.
Highly recommend this modification.
ID:	358596Click image for larger version
ID:	358597Click image for larger version
ID:	358598Click image for larger version
keneramirez is offline   Reply With Quote
Old 01-03-2020, 02:52 PM   #2
2019 30' Classic
Pleasant Garden , North Carolina
Can you supply some material sizes and measurements please?
jlandreth is offline   Reply With Quote
Old 01-03-2020, 03:28 PM   #3
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Attachment 358596Attachment 358597Attachment 358598Attachment 358599
guess I am wondering what the issue is with condensation under the matress?? We have twins also on last 3 AS's and no issues, even camping in FL...we use a dehumidifier which takes all the moisture out of the air... Please enlighten as to what is happening with your AS...what size, etc..
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 01-03-2020, 04:55 PM   #4
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
He wasn’t talking about humidity in a warm climate. Water vapour condenses on cold surfaces such as the platform under the twin mattress over the outside storage compartments. Does it get in to the 20s F in Florida?
Ray B.
Adventure.AS is offline   Reply With Quote
Old 01-03-2020, 05:45 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Very smart mod. I’ve never had the experience you and others have talked about (mine’s a FB with the mattress over the outside storage) but your mod is so good - the factory ought to consider that on every model! Well done!
Old 01-03-2020, 08:10 PM   #6
2018 27' Globetrotter
Mooresville , North Carolina
A product that serves the same purpose and might be a little easier project is called Hypervent. It provides air flow under the mattress. You can add extensions under your mattress and set the Hypervent on top and get the same result. See my post “Recent Globetrotter Modifications” in the Globetrotter forum for additional info. It would probably save you some time and effort.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is online now   Reply With Quote
Old 01-03-2020, 08:12 PM   #7
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
GOUSC - We hit “Save” at the same time! I got this idea from you...
OP, Nice job with fitting the plywood and cleats - very professional job! This is a worthwhile upgrade.
Moisture under the mattresses is a common problem in the marine applications as well as RV’s. There’s a product called Hypervent that goes between the base and mattress to allow airflow eliminating the chance of mold and mildew.
I installed some under our Globetrotter twins and added a piece of 1/2” plywood to extend the support for the mattress.
Here’s where I got the Hypervent: https://www.defender.com/product.jsp?id=1818021
ID:	358624   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-03-2020, 09:09 PM   #8
Bulverde , TX
I bought two sheets of thin plywood (top grade) and a handful of 1/4”x2” pieces to make it. I used a cutout of rigid insulation I’d tried to use before to eliminate the condensation (helped but didn’t completely solve it and didn’t add any additional support) as a template.
The part that most pleasantly surprised us was how much the extra support makes a difference. Makes the bed feel bigger and keeps the sheet from slipping off the mattress as much. It’s also nice to be able to sit on the edge of the bed to put on shoes and such.
Old 01-03-2020, 09:16 PM   #9
Bulverde , TX
We have a 2017 25’ RB (Twins) Flying Cloud. We also use a dehumidifier but when camping in freezing temps the mattresses kept getting wet under them due to the cold storage underneath creating condensation when up against the warm mattress. I spent a month in NC last winter and it was a constant struggle. Ended up installing 3/4” rigid insulation board as a way to help, but it still didn’t completely resolve the issue.
Old 01-03-2020, 09:18 PM   #10
Bulverde , TX
Yeah, I saw that but wanted to get the extra support while I was at it.
Old 01-04-2020, 09:16 AM   #11
2018 30' Classic
Sioux Falls , South Dakota
Send a message via Yahoo to Kyet
I see many posts about the cold storage underneath the twins. Has anyone tried insulating the "ceiling" of the storage area itself. I wonder if that could help. The air under my Queen seemed to be conditioned with both heat and cold (Classic w/ the ALDE). Thanks for all of the info as I embark on another trailer with twins this time.
Kyet is offline   Reply With Quote
Old 01-04-2020, 09:39 AM   #12
gypsydad's Avatar
Thanks for the "education" on this...we have camped "occasionally" in 20' weather in Tetons on way from MT, but not often. As you may know, it can get into the 20's here in TX for a few days, and we do keep our AS furnace on as we store on our property; just not sleeping in it during those cold spells. Never looked or noticed an issue with mold or mildew, "yet"!
I think your platform support or the Hypervent material seem to solve the problem, and look like good solutions. Doesn't seem to be an issue during storage thankfully. Thanks again, for bringing this to our attention!
Old 01-04-2020, 02:07 PM   #13
Napa , California
We extended the twins bed platform as well (took out the original boards and created new ones that were full mattress width with a finished L oak edge. Then we added some thin antimicrobial padding underneath the mattresses. Much more comfortable, the beds stay made, the cabinets underneath are easier to open and close and there is no mold or moisture either. Overall, well worth the effort.
Atwebs is offline   Reply With Quote
Old 01-04-2020, 10:37 PM   #14
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I'm not sure this will work 100% of the time, but my friend and I use heated mattress pads. I took and old pair of suspenders, cut them apart and hooked them to the bottom of the pad crossways under the mattress to keep it in place. The pad uses very little AC and there may be some DC ones on the market. That and my CPAP last all night on my set up. I have not noticed moisture below. But, if i did, I would add a layer of insulation board on the bottom above the storage space. My electrical equipment is under there and it may be providing enough warmth to keep thing dry. If EMS is a problem you could ground (bond) the aluminum foil surface to the electrical system.
guskmg
Old 01-06-2020, 09:18 AM   #15
2019 30' International
Pennsylvania , Pennsylvania
I installed the hypervent, but will likely do this elevated platform, it allows for a sorely needed width extension
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-31-2020, 09:32 AM   #16
dmbecke's Avatar
Des Peres , Missouri
Following
dmbecke is offline   Reply With Quote
Old 05-31-2020, 09:50 AM   #17
pjshier's Avatar
2017 27' International
Wasilla , Alaska
me three on the extension
I added some width by attaching some relatively thin (less than 1/2 inch) strips of high grade plywood with rounded corners. The strips are about 8 inches wide, and do not extend all the way from the foot to the night stand. Thicker material would produce a lengthwise bump along the edge of the mattress without replacing the entire bunk top. The thinner material is imperceptible and entirely adequate for the purpose.
Not craftsman-like but supremely functional and easily removed. Solved all the aforementioned utility issues. I can see where the venting would be very useful and will look further into the hypervent.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 06-03-2020, 09:11 PM   #18
gypsydad's Avatar
We are still monitoring this and have not done anything yet. NC in November, Texas coast January for 5 days, then again in March for 3 days on the beach. No issues. Just did 10 days in Tetons last couple weeks; checked and again no issues. Is there really a problem or am I just lucky??
Old 07-03-2020, 07:09 PM   #19
2020 25' Globetrotter
Malibu , California
I added 1/2 inch cabinet grade plywood extended 4 inches out and on top of stock ones just for the support. No more pushing the mattress back in and easier to make bed, change sheets. I did not have moisture problems before but that is for another day if I do.
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
Garfish is offline   Reply With Quote
airflow in jalousie windows jrossingaul Windows & Screens 9 07-16-2015 05:31 PM
airflow elbundi Classic Motorhomes 7 10-05-2009 05:23 AM
Twin bed support question conniera@yad General Interior Topics 6 05-20-2009 08:18 PM
airflow for converter JK3500 Batteries, Univolts, Converters & Inverters 2 11-21-2008 05:36 AM
anyone ever balance the airflow on a furnace? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 18 11-25-2003 12:16 PM
