03-10-2021, 09:27 AM
2021 30' Flying Cloud
2020 25' International
minneapolis
Door can potentially smash the window
Anyone come up with a good solution to eliminate the possibility of breaking the window?
• The obvious...never open the window. In this case, a way to secure the window, not allowing an unaware person from opening it.
• Limiting door travel. Somehow keeping the door from opening past 90 degrees.
• last and preferably not: have a new door made that hinges on the right.
03-10-2021, 09:30 AM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
Can't tell by the pic, but wouldn't you have the same problem with a right hinge door with the curbside front window. Looks close from the pics.
03-10-2021, 09:41 AM
minneapolis
Yes, though it’s the bedroom window, we wouldn’t open that as often. The door won’t contact the bedroom window until the door is fully open. I hit the window yesterday opening the door just past 90 degrees. Thank goodness it wasn’t a hard hit and the window was only half open.
03-10-2021, 09:45 AM
2009 34' Panamerica
2005 28' Classic
Still
Makes sense. My vote would be some sort of stopper. Many SOBs I've seen have them. Do a search using your favorite search engine for RV door stop and see if any of those make sense. If not, pretty sure you could MacGyver yourself something custom. Moving the door hinges, though possible would be my last and final option because I don't know what AS did to the shell on the non-latch side in terms of reinforcement, etc, let alone moving the step handle, which then has holes to fill and re-drill out if moving.
03-10-2021, 09:59 AM
minneapolis
Thanks guys! I just found another discussion with multiple other Airstream floor plans with this same issue. Everyone’s conclusion is never open the window...bummer...not the end of the world. It’s better having a window that doesn’t open over a wall.
03-10-2021, 08:33 PM
1969 18' Caravel
Greenville
, whereEverIroam
Shame on AS for such a poor design. Makes you wonder who came up with the idea, and who approved it, and why nobody there has pointed it out and fixed the problem.
03-10-2021, 09:57 PM
2017 25' Flying Cloud
Fayetteville
, Arkansas
Remove the window hardware that makes it operable.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
03-11-2021, 04:13 AM
2019 30' Flying Cloud
Grass Lake
, Michigan
My cargo trailer has a chain and spring attached from door frame to door that limits opening to 90 degrees. It’s not elegant but would work. I seem to recall seeing those on RV doors many years ago.
03-11-2021, 09:15 AM
2017 27' Flying Cloud
Volente
A pool noodle over the edge of the window at the point of potential impact would cushion the blow. Perhaps make it a non issue.
Jerry
2017 27 ft. Airstream FCFB
2015 27' Flying Cloud
Caledonia
, Michigan
When I had this window configuration, if I opened the window next to the door, I'd place a length of swim noodle, cut down the middle over the window edge and then let the window rest on the noodle, so not open much. I set it up so that the door would rest on the noodle if it was open all the way, preventing the window from being stressed.
03-11-2021, 09:25 AM
2007 22' International CCD
Corona
Because of the door versus window situation, we simply don’t open the forward window in our dinette. I have ‘window poppers’ to install on all the other windows. I suspect that front dinette window is well stuck to its gasket, so it’s not openable anyway. It works just fine for looking out of...
03-11-2021, 09:41 AM
2016 30' Flying Cloud
Kingston
, Ontario
We keep that window closed. Most annoying design flaw is having door hinges to the left. We had the door swing open while travelling full speed down the highway attempting to become a pancake as it hit the side. Luckily the window didn’t break but required factory visit to reshape it. Could have been worse!
03-11-2021, 11:09 AM
2021 16' Caravel
Long Beach
, Indiana
Instead of using an ugly brightly colored pool noodles, suggest using black pipe insulation tubing. You can get it in different inside and outside diameters. At least it would match your airstream.
Yvonne
03-11-2021, 11:23 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
In our case...NEVER hold the door open all the way with the furnace on.
It's never right for everyone.🥴
03-11-2021, 11:53 AM
Wherrwe
I made the window inoperable by removing the push arms and re-installing them on their opposite sides so they’re backward, but still there, hanging inside the window frame. That way they’ll never get lost.
03-11-2021, 02:05 PM
Silver Condo III
2015 30' International
Saskatoon
, Saskatchewan
Dealer solved the problem
When we had our 28' International we had the same issue. Our dealer (Can-Am in London, ON) had a great solution. They put a bracket with an eye on it on the side of the trailer and a similar one on the door. Then all we had to do was place the awning hook between the two brackets. This arrangement held the door at a 90 degree angle to the trailer. I will try and find some pictures.
Malcolm & Randy
WBCCI # 12523
03-11-2021, 02:23 PM
1967 22' Safari
MILAN
An old-fashioned fix
s1000pre, Now before you laugh out loud give this some real consideration! If there is available room, how about using the old-fashioned safety chain to limit the cabin door travel? It would stop the door short of the window edge if adjusted correctly and could always be un-hooked if the door needed to be fully opened. The chain could be covered with plastic tubing like swing set chains are but instead of protecting little fingers would of coarse be on the chain to protect door and screen! It sounds like it could be an option and would sure be cheaper than replacing a window glass or changing the door and frame to the other direction! Also no need for unsightly plastic swim noodles, Ha! Just a thought! Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
03-11-2021, 03:19 PM
2020 23' Globetrotter
Oakland
Best Solution
We have the same issue with our 2020 GT 23. The best solution would be for Airstream to design a window that could side up and down for these situations. A clever tech could come up with something that has a center horizontal “bar” that matches a line from either the door or or an existing feature on the body of the trailer to the non door side of the trailer. Just a thought because this issue is out of character with the engineering of Airstreams.
Mark
03-12-2021, 03:55 AM
2019 27' International
Rogers
, Arkansas
This is one of the reasons we didn't buy a 28'. It makes no sense to me. The other reason as Dart mentioned in post #12, opening into the wind while driving. I hear it does happen.
03-30-2023, 07:31 AM
Member
2023 23' International
Lakewood
, Ohio
Bracket Solution
Can you post some pictures of this?
