RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-03-2011, 03:08 PM   #1
Airstreamer
J5MM's Avatar
2012 27' FB International
Bellevue , Washington
Images: 78
Should I be worried about a noisy converter?
Oh I hope someone can help me. I am a little worried. Over the weekend we noticed our Parallex 7300 converter has been making a soft high pitched, buzzing-squeak like noise every now and then.
While it was the making the sound, I happened to turn on a light (the stove top range exhaust hood light, to be specific) and as soon as I flipped the switch, the sound immediately stopped. Then, turn off the light -- and the sound came back on.
This is our second coverter - the first one burned out and really scared me with all of the smoke in the cabin (which is why I am worried now).
Does anyone have any suggestions? I understand this unit is not the best and does fail -- is this sound it is making the beginnings of a failure?
Thank you so much for reading.
{blog}Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
J5MM is offline   Reply With Quote
Old 10-03-2011, 03:32 PM   #2
richinny's Avatar
2011 34' Classic
similar post here:
http://www.airforums.com/forums/f44/...ari-54341.html
Ricky
Old 10-03-2011, 03:34 PM   #3
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Not sure about your model, however these modern converters use a
"switching power supply" Basically turning on and off at a high rate of speed then going though a magnetic coil and converted to the charging voltage. Anyhow, that coil can make some noise, something a little loose, a metal plate near it. If your voltage is OK, unit does not feel hot to touch..it is most likely fine. And it will change sound with a change in load.
Jim in Pima is offline   Reply With Quote
Old 10-03-2011, 04:53 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
IMHO....best course of action.
Get rid of the P-lex..ours ruined 4 batteries before I wised up and replaced it.
And yes, it too was noisy.
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
Old 10-04-2011, 06:12 PM   #5
Airstreamer
J5MM's Avatar
Images: 78
Thanks everyone. So much. I will keep you posted with our course of action. At least this is happening now before the ski season hits where we will need power for the furnace. Oiy.
Old 03-11-2018, 03:47 PM   #6
2011 30' International
Purcellville , Virginia
buzzing converter
The Parallax converter on my 2011 Serenity International just started symptoms very much as you described, including the buzz stopping when I turn on the light over the range.
How did you eventually get this resolved ?
lovalabx3 is offline   Reply With Quote
Old 03-11-2018, 04:18 PM   #7
AirstreamJim's Avatar
2007 25' Safari FB SE
Lake Worth Beach , Florida
The original poster hasn't been on the forums in over 1.5 years. You're not likely to get a response from her.
It is generally recommended that you replace the original converter. If your Airstream has 30 amp shore power, replace it with a Progressive Dynamics PD-4655 converter. The install is easy - it took me about half an hour. This thread has an excellent pictorial step-by-step installation guide:
http://www.airforums.com/forums/f449...es-162905.html
You'll find the best price and service that can't be beat from www.bestconverter.com.
Good luck!
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 03-11-2018, 04:55 PM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I'm occasionally in contact with the OP through another venue. I'll send her a message, and make sure I remember the solution correctly.
In what has to be the quickest response in history, the issue was a failing converter. The converter was replaced, and all is well in her trailer's world.
Old 03-13-2018, 10:19 AM   #9
My converter is the Parallax Series 500 Model 555. I'll reach out to BestConverters for replacement/upgrade. Thanks
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 03:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 11:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 09:27 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 01:17 PM
