RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-30-2018, 02:52 PM   #1
2019 27' Flying Cloud
Scottsdale , Arizona
Wiring harness
New RVer with a new Airstream FC27FBT. Also a ham. Trying to find 20A of DC in the entertainment cabinet next to the stereo for my transceiver. Found this bunch of “unused” wires and am wondering if any of them carry 12VDC?
Dave
K7DAT
datwyver is offline   Reply With Quote
Old 11-05-2018, 09:03 AM   #2
Clovis , New Mexico
Find a wiring diagram for your model of airstream or get a cheap multi meter from Harbor Freight or off Amazon. A multimeter would tell you instantly.
powerwiz is offline   Reply With Quote
Old 11-07-2018, 03:17 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
HAm too V e 3 H I u
IMHO, remove all power, disconnect Ac and battery, and remove all fuses from the distribution panel
tone the lines to see where they go
you can try to test connectivity to the DC breaker panel, so that you can find what goes to what terminal. Then document WHAt is real in your unit. A year from now , you may forget. Take many photos and label them well for the future
also get the REAl schematic for your make and model for AS
If not online, a call them and they will send you the soft copies
waninae39 is offline   Reply With Quote
Old 11-07-2018, 03:55 PM   #4
2007 22' International CCD
Best way to power the transceiver is to run a separate set of heavy wires direct to the battery bus bars where the battery cables connect. Fuse the hot side there. For 20 amps, you need a minimum of #12 wire--the ones you have there don't look big enough.
In our AS, we have an FT-857 setup. The head is remote cabled to the desk in the rear of the cabin, and the main unit is mounted in the streetside wardrobe cabinet. The main unit is powered from a PowerWerks distribution panel mounted near it. The line from the battery bus bars under the front bed is a dedicated #12 red/black zip wire that ends in a 40 amp powerpole connector plugged into the distribution panel input. Makes it easy to shut it down when in storage. Antenna leads are also available that connect to feed-throughs that go into the refrigerator upper door area from the wardrobe. We can connect portable antennas there. A UHF/VHF whip is also run in through the solar panel combiner box that accesses the top of the wardrobe.
Wiring harness jwebb90162 Electrical - Systems, Generators, Batteries & Solar 2 02-07-2012 04:53 PM
Brake Controller Wiring Harness wlanford Brakes & Brake Controllers 3 08-01-2011 01:14 PM
Coach wiring harness to batteries ? John H. Classic Motorhomes 16 03-28-2011 11:52 PM
New wiring harness RiverRat Lights - Interior & Exterior 9 06-16-2009 03:42 PM
7 Pin Wiring Harness Replacement Jake Electrical - Systems, Generators, Batteries & Solar 4 09-27-2005 09:05 PM
