RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-06-2017, 06:33 AM   #1
gregwall's Avatar
2014 25' FB Flying Cloud
2005 30' Classic
Keswick , Virginia
Wiring a Rear View Camera on 25' Flying Cloud
I am posting because there is so little information on how to do this. I used RearView Safety because I have used their cameras in the past and I had a few of the parts. It is good quality, but their directions are lacking. This is 4-hour job if you have all the materials and tools. Step-by-step directions and 26 pictures are included in the attachment. I am happy to change the document or the technique on the group's recommendations. The truck gets wired this week, and I will post that part.
File Type: pdf Wiring a RearView Camera on 25 Airstream Trailer Op.pdf (7.95 MB, 179 views)
Greg
2014 25' Flying Cloud FB
2015 GMC Sierra Denali 6.6L diesel
Charlottesville, Virginia
gregwall is offline   Reply With Quote
Old 06-06-2017, 09:08 AM   #2
2016 26' Flying Cloud
Southlake , Texas
I mounted my camera up above rear window and ran the wiring on the roof. About every 18", I used a sticky pad with VHB and a nylon tie. At the front of the trailer, I routed the wiring behind the rock guards to get underneath the trailer. I mounted the connector to a bracket on the a-frame. Worked very well.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 06-06-2017, 10:37 AM   #3
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
That's a good idea Bgibs. How did you mount the camera?
Greg
Old 06-06-2017, 11:32 AM   #4
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
Dear Greg,
I, too, have a hard-wired, rear view safety camera that I mounted on my 27FB, although on its inside, lookout out the rear window --- see photo #1. That meant I had to run its wiring through a hole up into the cabinet, and then through a second hole back down out of the cabinet over by the wall --- see photo #2. The wiring then went through a hole in the floor and up to the A-frame, where I mounted the socket, to connect the wiring to the truck --- see photo #3.
ID:	286988   Click image for larger version
Name:	Camera socket.jpg
Alta & Richard, Olympia, WA --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 06-06-2017, 11:38 AM   #5
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
nice job and great write up
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 06-06-2017, 12:07 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I mounted my camera on the license plate the same as you did, but...
I ran the wire right into the license plate bracket to power the camera from the license plate light.
No wires are visible.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-06-2017, 04:41 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I mounted mine above the license plate. Ran the wire though the skin down behind the bed head padding, though the top of the bed pedestal into the cavity where the AC power comes in, forward, behind the roadside lower radius covers, over the water heater, under the lavatory cabinet into the refer compartment, down through the floor, forward to the front through the crossmember lightening holes to the front through the tongue frame. That camera has paid for itself many times over!
guskmg
Old 06-06-2017, 06:11 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Gotta hide those wires better than that. OUCH, power camera from tag light or something.
Old 06-06-2017, 06:39 PM   #9
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
Why didn't you just run the cable straight down from the camera, behind the license plate and then under the trailer? I don't see a storage compartment you had to avoid.
2019 Ford Expedition Platinum
Old 06-06-2017, 07:14 PM   #10
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
Originally Posted by Rgentum View Post
Dear Greg,
Thanks Rgentum. That's a nice setup. What camera did you use?
Greg
Old 06-06-2017, 07:19 PM   #11
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
Thanks m.hony. I had read your comment about this some time ago and didn't get it. Now that I have done this and read your comment again, I've got it. That is exactly what I am going to do tomorrow morning. I'll add a couple of pictures. Thank you!
Greg
Old 06-06-2017, 07:26 PM   #12
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
guskmg
Thanks guskmg. That sounds pretty cool. Not sure I could do it, but I like it.
Greg
Old 06-06-2017, 07:27 PM   #13
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
Yep, you're right. I'm on it tomorrow morning.
Greg
Old 06-06-2017, 07:31 PM   #14
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
I'd have to come over the rear bumper to keep going straight, so I was going to come straight down and then turn left on top of the rail and then under. But I'm going to try m.hony's way tomorrow.
Greg
Old 06-06-2017, 09:23 PM   #15
Plover , Wisconsin
Question Worth it?
guskmg
Please tell us how the camera paid for itself.
Oxen
Oxen is offline   Reply With Quote
Old 06-06-2017, 09:32 PM   #16
Plover , Wisconsin
Question By wire by air?
I expect that your camera sends its signal over the air. True?
Old 06-07-2017, 03:26 AM   #17
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
Hi Oxen. No, it will all be hard wired, connecting to the truck with a quick connect cable. I will plug it in similar to the way we plug the trailer into the truck. I like the reliability of a wired system.
Greg
Old 06-07-2017, 07:29 AM   #18
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
I can't see where you went with the cord m.hony. I would have to drill the hole bigger, which is OK, but there is no exit that I can find between the inner and outer skin or through the floor to get underneath the floor.
Greg
Old 06-07-2017, 10:52 AM   #19
m.hony's Avatar
2013 30' Classic
Rear bedroom island queen Classic-
Removed headboard and got into the wall to mount wireless transmitter just inside wall from license plate and camera.
Camera powered by tag light.
Run "lights on" all the time to power camera.
TAC #MS-10
Airforums #70955
Old 06-07-2017, 11:29 AM   #20
Rgentum's Avatar
This is the camera I used:
https://www.rearviewsafety.com/safet...uminators.html
This is the system I bought:
Problem: The camera has an infrared sensor in it such that when it detects darkness, it turns on a number of LED lights parallel with the camera lens. I've mounted the camera INSIDE the trailer, looking out the back window. During darkness, the LED lights turn on, reflect off the back window, and obscure the image of the camera. I called Rear View Safety about that problem, asking how I could turn off the LED lights at night. "You can't," they said, "You'd have to get a different camera." So yesterday, I disassembled the camera, removing its front face from its body, & found a simple, tiny plug & socket that connects its electronics to its LED lights. I removed the plug & reassembled the camera. I don't have my truck connected to the trailer right now, but next time I do, I'll check the camera at night to see if it stills works & if its LED light no longer work. I hope to have found a solution.
backup camera, rear view camera, wired camera system
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 06:01 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 05:10 PM
Rear View Video Trailer Camera Mount Location chaimemet Towing, Tow Vehicles & Hitches 10 02-07-2008 09:15 PM
Sony Rear View Camera gunworks Electronics & Connectivity 1 10-08-2005 02:27 PM
