Old 10-13-2020, 10:09 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Wireless back up camera
I am looking for a wireless back up camera that does not require screws to attach. I am only looking to use it when I am backing up into a space.
urnmor is offline   Reply With Quote
Old 10-13-2020, 10:12 AM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Vinnie showed us a setup he uses around his shop using a Voyager camera attached to a motorcycle battery that he sets in the rear bumper of the trailer. Very clever.
sheriff1 is offline   Reply With Quote
Old 10-13-2020, 10:41 AM   #3
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I have a Voyager but I have played with my GoPro using a suction mount to the back window. The GoPro would require no wires just the camera, mount and smartphone.
I have compared the resolution of the Voyager to my Hero 7 and there is no comparison as the GoPro beats the Voyager for image quality.
The only concern with the GoPro is the connection it makes to the phone. Mine worked but it was not super quick to connect initially. Seemed fine after the connection was made.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 10-14-2020, 07:16 AM   #4
urnmor's Avatar
Berlin , Maryland
Thank you for your responses. I took a gamble and purchased the Wireless Backup Camera with 5" Monitor Rearview License Plate HD Digital Signal Reverse Backing Up Cam Night Vision Waterproof Rear View on Amazon prime day. As it was under a 100 dollars I thought it would meet my needs and be worth a try.
Old 10-14-2020, 11:15 AM   #5
Ashland , Oregon
Sounds like a possible solution - how do you plan to power the camera - through the license plate light?
lanetim is offline   Reply With Quote
Old 10-14-2020, 02:05 PM   #6
urnmor's Avatar
Berlin , Maryland
Not sure I am going to have to do that as it is suppose to connect via wifi. If not I will have to connect using a wire. I will let you know once I receive it and have it connected.
Old 10-14-2020, 02:20 PM   #7
PB_NB's Avatar
2019 22' Sport
Much like the Voyager camera, which usually gets its power from a 12V DC source, is connected to the middle marker light. The license plate camera will probably pull power from the 12V source at the license plate frame. There is a chance that it could be battery powered as well but that brings up a whole new set of challenges such as making sure it is charged when you need it.
Peter.
Old 10-14-2020, 03:54 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My MacGyver 'drill no unnecessary holes' policy required I use Industrial Strength Velcro to attach the camera above the window..😂
Ran the wire down the rain-gutter, under the window weather strip & inside the trailer to a lighted on/off switch plugged into the 12v power port between the twin beds.👍
NEVER MIND...I'm using a high mount rear view camera not a B/U camera.🥴
ID:	380851   Click image for larger version
ID:	380853   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 10-16-2020, 07:58 PM   #9
2013 23' FB Flying Cloud
Burien , Washington
This has worked well for us. Uses WiFi, internal battery. I mounted it with velcro like Robert Cross used. Can easily be repositioned after mounting with adjustable pivot on base. I use it full time while on the road with an auxiliary Anker battery in waterproof case, also velcro mounted. Wifi signal is quite strong, some stuttering in urban areas, otherwise pretty smooth.
720p 32GB Wireless Portable Magnetic Base Battery Powered RV/Trailer/Truck Hitch Backup Camera NuCam WR Surveillance IP Camera w. 1/4"-20 UNC Hole, Motion Detection Recording, Night Vision & Battery
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
SeaJim is offline   Reply With Quote
Old 10-20-2020, 08:32 PM   #10
2014 28' Flying Cloud
Phoenix , AZ
I like this no drill solution to having a rear view camera so I can feel comfortable changing lanes without having to wake up my copilot and/or second guessing my depth perception when he depends on me for same. The only "hitch" is we don't have a 12V outlet in the bedroom of our 2014 Flying Cloud 28RB. There are inverter outlets in the bedroom so I assume we could leave the inverter on and tap into one of those. Any suggestions?
vwii is offline   Reply With Quote
Old 10-24-2020, 08:23 PM   #11
urnmor's Avatar
Berlin , Maryland
My thanks to all I decided to see how the NUCam works.
Wireless back up camera.. Recommendation Lothlorian Audio, Video & TV 160 10-14-2018 10:24 PM
Wireless Back up Camera-Jackson Center Mrjkq On The Road... 59 04-16-2016 04:49 PM
Wireless Backup-Camera campadk Electronics & Connectivity 31 11-29-2010 08:32 AM
Wireless Backup Camera for Your Bambi campadk Electrical - Systems, Generators, Batteries & Solar 39 07-23-2007 07:08 AM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
