07-07-2019, 06:28 PM
#21
2015 27' Flying Cloud
Portland
, Oregon
Originally Posted by chugchug
Since you are using a jetpack, you can connect it directly to the external antenna with a splitter like
Using one of those with the regular omnidirectional antenna that came with the weBoost RV (and without the booster or the internal antenna) I am getting 9-12 db gain and about 10 time the down/upload speed
I figure the booster is only needed to drive the signal to the internal antenna and that will be necessary for any device that doesn't have an antenna plug such as a cell phone.
Your right, I could use that to connect directly to the jetpack but then I couldn't use the amplifier.
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
07-07-2019, 06:42 PM
#22
2018 25' International
Belmont
Correct, no need for the amplifier or the internal antenna. Also no need for the power supply or trying to figure out where to tap the 12v.
07-07-2019, 07:14 PM
#23
Belmont
Another solution that worked well was to hoist the jetpack on a long pole. This way the jetpack was receiving a stronger signal. I was still able to connect to the hotspot that it creates while I was sitting inside. In this case, the only thing you need is a long pole and a way to attach the jetpack to it. This might also work with a cell phone as a hotspot, but it will be difficult to take calls-
I had to take it down every so often to recharge.
To protect the jetpack from the elements, I taped the it inside an empty water jug (after cutting off the top) and placed that upside-down at the top of the pole.
07-18-2019, 06:44 AM
#24
2015 23' FB Flying Cloud
Omaha
, Nebraska
03-16-2020, 09:44 AM
#25
2019 27' International
Rogers
, Arkansas
Does the External Antenna Type Make Much Difference?
I currently have the weboost 4G-X and it came with a little magnetic type of antenna, I see on their website they have lots of external vehicle antennas to choose from. They range from $15.00 to $200.00 which one is the best for an AS? Does it make much difference? Does the 75 ohm work better than the 50 ohm?
03-16-2020, 10:17 AM
#26
Belmont
For a permanent mount I would chose an omni directional antenna, so I don't need to aim it. A yagi antenna will have a higher gain, but only in the one direction it is pointing at. So it needs to be fiddle with all the time.
As far as impedance. You want to match your device. If it is 50 ohm than you want a 50 ohm antenna. You will lose 3db (1/2 the energy) if you connect the 50 ohm antenna to a 75 ohm input device.
03-16-2020, 10:16 PM
#27
Phoenix
For a permanent mount I would chose an omni directional antenna, so I don't need to aim it. A yagi antenna will have a higher gain, but only in the one direction it is pointing at. So it needs to be fiddle with all the time..
I find I set my directional antenna once and it’s fine for the duration of our stay. That extra gain is sometimes worth it.
04-12-2020, 03:16 PM
#28
2020 25' Globetrotter
Los Gatos
Weboost 12v fused power supply
It has pos and neg wire ends so how do I connect to my 12v supply. No 12v plugs in my AS. Could connect to fuse box but Weboost controller is at opposite end under dinning table, too far. Many USB ports but how do I convert those
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
04-12-2020, 06:45 PM
#29
2018 25' Flying Cloud
Portland
, Oregon
There is 12v going to the back of all of your USB chargers if that helps. There’s also 12v behind the fridge, behind the radio, behind the reading lights, to the heater, etc. Just be sure to use the inline fuse holder that came with it.
04-12-2020, 07:09 PM
#30
Los Gatos
Wanted to install cig lighter and UBS combo outlet where OEM UBS plate is. The combos need 12 v to each. Just splice leads so I can hook up both?
04-12-2020, 11:57 PM
#31
Portland
, Oregon
Yep, that’s all it takes!
04-13-2020, 12:05 AM
#32
2007 22' International CCD
Corona
Weboost 4G-X Drive RV Antenna Install Placement
Just mind the proper polarity. Check the wiring to be sure you get positive to positive, negative to negative wires.
04-13-2020, 12:58 PM
#33
Portland
, Oregon
True, some genus in a bygone era decided that RV 12v systems should use black and white wires where black is positive (!) in some places and red/black in others where black is negative like god intended. I guess they were taking a cue from the way home AC circuits are color coded with black as hot.
Anyway that confusion has caused many a blown up component over the years.
