RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-15-2020, 07:25 PM   #1
2014 27' FB Classic
Draper , Utah
Exclamation Use Existing Coax for WeBoost RV 65??
Hey friends --
I'd like to avoid running wire when installing the WeBoost antenna and two associated devices. Can I use the existing coax cable? If so, how? Where would I put the first box (with an IN and OUT port)? And the second box which is the actual antenna?
This is the kit I bought: https://www.weboost.com/products/connect-rv-65
Can I connect the first antenna (with in/out ports) to a coax near the DVD player?
And can then broadcast decide be daisy-chained through the coax that outputs in the bedroom (see attachment)?
Many thanks in advance 🙏
Seneca is offline   Reply With Quote
Use Existing Controller with Portable Panel? CoorsLite Generators & Solar Power 2 05-21-2018 06:59 AM
Bought used AS, can I keep/use the existing numbers? augopher WBCCI Forum 5 07-23-2017 06:37 PM
Replace coax on 1997 34' Excella Aviator Audio, Video & TV 2 10-28-2011 09:35 AM
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 04:24 PM
Outside Coax feed Krazykraut General Motorhome Topics 2 10-06-2002 06:39 PM
