Old 10-06-2019, 08:43 AM   #1
2020 25' Flying Cloud
Atlanta , Georgia
TV--not
I'm finally getting time to start setting up the entertainment electronics in my new 2020 Flying Cloud, starting with the TV (only coincidently in time for the Packers/Cowboys game, by the way). In short: a very nice screen of black and white static, which I haven't seen since "It's 10 PM, do you know where your children are?"
I am theoretically using the antennae. I ran through the autoprogram to find all channels. Of course it didn't find any in CATV etc, but there should be a half dozen on the regular TV. It found none. (I should say that I'm on shore power.)
My first guess is that it's the antennae. I'm working on the TV in the salon, which doesn't come out from the wall. But it looks like everything is connected properly. Another clue is the FM radio is staticky. Is there a way to check the antennae?
Belbein is offline   Reply With Quote
Old 10-06-2019, 09:12 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The FM antenna is not related, it is the the little rubber ducky antenna on the top rear. It is possible that antenna became unplugged behind the radio. You will have to remove the radio to find out. The radio is a standard car mount and your owner's pack should have long metal key to insert on the sides to release the latches.
The TV antenna is the mushroom on the roof. If connected properly you must push the button on the amplifier near the TV, you will see a green light, then you can watch TV stations that are broadcast. Do that and try your scan. The amplifier must be off when you do your scan of cable channels, when you have cable hooked up to the connector on the exterior.
Larry
lsbrodsky is offline   Reply With Quote
New Airstream Owner - not impressed and would not recommend Uncle Milky 2016 - Current Flying Cloud 157 06-07-2019 05:55 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 01:21 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
