Old 01-19-2022, 02:09 PM   #1
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
T-Taps
Do folks reco them in our traveling/shaking tin cans to tap into an existing 12V wire? Do they hold? Thanks!
steilkurve is offline   Reply With Quote
Old 01-19-2022, 02:31 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Depends a lot on what you are doing. For putting in another LED light on a lamp circuit they do ok. Worst that can happen is the light goes out. For the brakes, having them hang out in the muck under the trailer .... nope ...
Old 01-19-2022, 03:22 PM   #3
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Hi
Thanks Bob. This would be to feed a cellular router so inside, tucked away in a cabinet. I assume based on your post that would be an acceptable application.
Old 01-19-2022, 03:48 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
They work, usually.
But in the process they often cut a few (or more) strands of wire in the wire being tapped. This leads to lower capacity and and increased likelihood of future wire breaks.
I keep a couple in my tool box but save them for emergency repairs which will be redone later on.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-19-2022, 03:56 PM   #5
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Originally Posted by richard5933 View Post
They work, usually.
Ok. Good advice. Thanks.
Old 01-19-2022, 04:49 PM   #6
1994 25' Excella
Soldering is the old-school way of tapping into an existing wire. If you're good with a soldering iron and the wire is in an accessible location it is an option.
I just did a little searching to see if there are upgraded or better options for than the old T-taps. I found these:
https://www.posi-products.com/posiplug.html
Never used the before, but they do look like a great upgrade from the style which uses pliers to run the metal guillotine on the wires. Looks like they're available at Amazon and other similar places.
Here's a video from Crutchfield showing them in use:
Richard
11018
Old 01-19-2022, 07:56 PM   #7
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Thanks for this. Seems like a sturdier option than the old guillotine ones. Appreciate it.
Old 01-19-2022, 08:20 PM   #8
Bothell , Washington
I've used a lot of these in a larger size on an outdoor low voltage lighting system. You might want to add shrink wrap on the male end to secure the wire even more when you screw these down. It is possible that the wire can pull out with a bit of tension ~ unless you feel that no tension will ever be applied to that wire.
KPD67 is offline   Reply With Quote
Old 01-19-2022, 08:40 PM   #9
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Well, not a lot of intentional pulling but it’ll obviously be subject to the constant road vibrations. Smart idea to shrink wrap on top of it.
Ordered a few. I shall try! Thanks again.
Old 01-20-2022, 05:36 AM   #10
1994 25' Excella
Please post a followup. I'm curious to see how they perform in a real-world situation.
Now if only we could find a way to totally shrink wrap a T-fitting...
Richard
11018
Old 01-20-2022, 07:35 AM   #11
Half a Rivet Short
2022 Interstate 24X
Hi
If you are looking for alternatives, this is one:
Old 01-20-2022, 09:00 AM   #12
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Will do!
Old 01-20-2022, 09:47 AM   #13
vintage6t's Avatar
2005 30' Land Yacht 30 SL
South Windsor , CT
Wrapping the fitting in self fusing Silicone tape will provide some strain relief as well as a moisture barrier.
vintage6t is offline   Reply With Quote
Old 01-20-2022, 12:11 PM   #14
2017 25' International
West Lake Hills , Texas
Hi
I use the WAGO lever nuts quite a bit…home, rental properties, AS, etc. They work great in cramped areas. The MicroAir easy start butt connectors weren’t big enough for the wires, so I used the WAGO connectors. I carry various sizes and types in the AS electrical kit. I can’t remember the last time I used an old-school wire nut anywhere.
Fungus is offline   Reply With Quote
Old 01-21-2022, 07:15 AM   #15
Half a Rivet Short
2022 Interstate 24X
Hi
At least to me, the big advantage of the WAGO gizmos is that they deal with stranded wire better than wire nuts do. They still are not perfect for super fine strands.
Can't get water out of taps....new person bls72bmw Base Camp 14 04-11-2021 07:42 AM
City Water Not Making it to the taps/shower/toilet... Lara_From_NC Airstream Trailer Forums 7 02-05-2019 11:59 PM
still no hot water at the taps the welshman Water Heaters, Filters & Pumps 8 01-20-2008 12:07 PM
Kitchen faucet taps needed michael foster Fresh Water Systems 4 01-13-2008 05:37 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
