Old 09-18-2023, 10:51 AM   #1
Myakka City , Florida
Suggestions for Voyager Back Up Camera
I am looking for suggestions for a better alternative to the Voyager Back Up camera. We have a 2017 Classic and have not been happy with the quality of the camera. The suction cup holder snapped, again and fell breaking the antenna completely off. The model we have has been discontinued.
Thank you
thebaum is offline   Reply With Quote
Old 09-18-2023, 10:56 AM   #2
Oak Park , Illinois
There are some additional problems with the Voyager that the factory described to me in terms of signal. I have a 30 footer and I have only been able to use the camera 1x due no signal.
The factory fix is to drape a cable, which seems like a non-issue to me, so I too would be interested in seeing a solution that would work for trailers longer than 25-28', be it making the Voyager work or replacing it with a minimum of modifying the camera bracket.
sfranklin is offline   Reply With Quote
Old 09-19-2023, 01:29 PM   #3
2017 25' International
West Lake Hills , Texas
I use a Haloview in which the monitor straps to the rearview mirror of the truck. It is a natural place to look for what's behind me. I don't really need to see the front of the trailer all the time. The monitor has enough reflection when switched off that I can leave it mounted for the entire trip, even when unhitched.
I tried to tap into the powered mirror for the monitor's power but there wasn't enough juice there. I don't like any distractions in the cab (dangling wires). I ran the power cord above the headliner, behind the plastic cover on the passenger-side post, behind the AC vent, and into the passenger-side kick panel under the glove box. The F-250 has a fuse box there that you can piggyback an outlet. My F-250 has upfitter switches so I tapped into one of those at the same spot as mentioned above. I plugged the stock power cord into a 12V outlet that I had wired to the upfitter pigtail that comes through the firewall and secured with a zip tie. Removing the plastic cover on the post was easy -- just be careful with the airbag and secure the wire to avoid the airbag. The wire is completing hidden.
I also bought some spare rubber straps for securing the monitor to the mirror. Those things look like they might be easy to lose.
Installation of the camera was simple using the existing wires. Seems that I used the original bracket but I can't be certain. It's been a day or three since I installed the camera. The camera is not wired to the monitor. There is a bit of lag but not enough to warrant installing the other antenna.
Fungus is offline   Reply With Quote
Old 09-19-2023, 02:07 PM   #4
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
If your TV is an F250 or larger, get the Ford Trailer Camera and TPMS System if your truck is compatible.
JEWare
John Ware is offline   Reply With Quote
Voyager back up camera 4t9ers Electrical - Systems, Generators, Batteries & Solar 51 07-25-2020 10:11 AM
Voyager Back Up Camera with Apple Play? CarrieAnn Electronics & Connectivity 16 11-18-2019 11:02 AM
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 06:54 PM
Back up camera voyager somer128 Audio, Video & TV 2 05-30-2017 09:00 PM
