06-30-2017, 04:20 PM
2007 27' International CCD FB
San Diego
Solar Upgrade - No need for multistage converter?
I'm in the process of doing a modest power systems upgrade on my 27FB. Key to the upgrade is adding a small ~200W solar system, along with new 2x grp 27 batteries.
A key upgrade that many do seem to be the upgrade of the stock Parallax 7355 55amp converter to a multi-stage PD 4655. This is to maximize battery life by having a proper float mode when plugged in for an extended time.
That said, I'm not sure I really need the converter upgrade, especially with solar. I store my AS in the open. Which means I will rarely have it plugged in for extended lengths of time, and the solar charger will keep the batts topped off. Only time I may be plugged in will be for active vacations or running A/C with a generator.
Is my thinking correct on this?
06-30-2017, 04:37 PM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
What sort of conditions will you be operating under? When the batteries get hot (120F) or cold (40F) the "magic voltages" for float or bulk charge change significantly from what they are at 70F. To the degree that dropping from a "bulk charge" voltage down to about a half volt lower "float charge" voltage is important. The > half volt change in the voltages is equally important.
As you shop, at least *consider* one of the (many) systems that will let you put a temperature sensor on the batteries. Yes, you *will* have to get a wire to the sensor. No pain, no gain ....
06-30-2017, 05:15 PM
San Diego
I'm in the desert, SW region of the continental US. So will generally be in warm sunny weather areas.
While I'm an engineer with elitist thoughts, cost is a design parameter too, where practical 90% solutions generally represent the best value.
I'll have to do some researching on solar controllers, and at least look into temp sensor controllers.
07-01-2017, 03:55 PM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
There are a number of places on the web where you can find the voltage vs temperature curves for various battery types. There's not a lot of deep dark secrets involved. It's mainly something that was pretty tough to do decades ago and now is much easier.
07-01-2017, 05:36 PM
2015 30' Classic
Pleasanton
I didn't think it was worth upgrading my converter since my solar charger is properly maintaining the batteries.
When you're connected to shore power just leave your Use/Store switch in the Store position.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
07-02-2017, 10:20 AM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
Depending on the model and year of your AS, the "store" switch may or may not take the battery out of the loop on shore power ....
07-03-2017, 12:51 AM
2015 30' Classic
Sherwood
, Oregon
I had 120W factory Zamp solar on my 2014 International Serenity and always had the battery switch in "store" from March to November when outside. Batteries were always full according to the controller. When I stored her in the garage for winter I left it in "store" and put an external float charger on the batteries. Sometimes it is the basic solution that makes the most sense. I guarantee that you have more sunshine where you are.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
07-03-2017, 01:37 AM
San Diego
That's the confirmation I'm looking for. I can always chase better but in practice, it's just not necessary sometimes.
I'll leave in the stock converter charger for now and focus on a solar upgrade this time around. And inverter...
07-04-2017, 02:05 PM
2015 30' Classic
Pleasanton
Hi
Very true. Do you know the cutoff date when AS changed to isolate the batteries while on shore power?
Al, K6IV
07-05-2017, 09:24 AM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
What they do still depends a bit on the model. The 2018's disconnect to a greater extent than the 2017 model year trailers. The 2018's still have stuff like the propane detector on the battery when it's in "disconnect".
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
12V converter/battery/monitor upgrade
dznf0g |
Batteries, Univolts, Converters & Inverters |
35 |
01-31-2016 08:49 PM |
Converter,battery and solar upgrade
SilverSinbad |
2 |
01-19-2015 11:57 AM |
replace and upgrade converter fuse block
nikiarntz113 |
3 |
11-28-2010 10:24 AM |
Converter Upgrade
nickmeloy |
2 |
10-11-2010 04:50 PM |
Upgrade converter in '05 Classic 31?
bandboss |
3 |
03-01-2006 06:58 AM |
