RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-25-2019, 03:56 PM   #21
2018 16' Sport
St. Louis , Missouri
I feel it is the best add on for a trailer. Are you pre wired? The cost has become reasonable. A couple of panels and a solar controller and you have a solar start. I don't have all the answers but if you need to ask questions contact me.
Sport 16 STL is offline   Reply With Quote
Old 12-25-2019, 07:52 PM   #22
2017 19' International
Rosemere , Quebec
Originally Posted by Sport 16 STL View Post
Nice install, could you put more on the opposite side if you wanted? On my 16 Bambi, I have one on each side which helps if I am parked in partial shade. Thanks for the pics.
Not really because I have the Winegard wi-fi antenna wiring than the bathroom vent further back. One more would be on the ground or on the top of my truck's box, hooked up to the front solar outlet by the battery with its own charge controller.
ID:	358203   Click image for larger version
Projet2907 is offline   Reply With Quote
Old 12-25-2019, 09:40 PM   #23
Firefly77's Avatar
2008 19' Safari SE
Hocking Hills , Ohio
Good question. I checked my manual and it appears so. There is a good set of diagrams and instructions on DIY roof mounting panels, running the wires down through the reefer vent to connect to the electrical harness in the cavity behind the exterior fridge access door. I'm no engineer, but it looks doable. I'm just handy enough to get myself into trouble
Nature is the perfect imperfection
Firefly77 is offline   Reply With Quote
Old 12-26-2019, 08:22 AM   #24
2018 16' Sport
There are plenty of people here that can help. Mine came with wires already run. I had someone install the two panels, but I installed controller. Also built a 200watt suitcase and running it through the same charge controller. That part is new and have not used it on the road yet.
Old 12-29-2019, 05:26 PM   #25
bambi-Lily
2016 19' International
encinitas , California
Protech- what is the issue with flex panels. We installed 300W hit summer and they are working like a charm on our 19 ft.
pegjust is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 07:58 PM
'06 Bambi: Replace a/c with solar panels ESCAPE POD Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-26-2016 02:17 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 07:04 AM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 05:53 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 08:47 AM
