RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-30-2020, 07:55 PM   #1
2021 23' International
P , California
Solar for 2021 23FB International
I just bought a 2021 23FB International and since it was so expensive to have the dealer install solar I decided to wait and learn more. My plan is for the highest wattage single roof panel and replacing the two stock Interstate batteries with two Lithium Ion batteries. I'm guessing that I'd need a charge controller but what else? Who makes the best batteries and electronics? Is this a difficult install?
Is there a company that sells kits for AS?
viking1 is online now   Reply With Quote
Old 10-30-2020, 09:06 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Do a search here for ‘solar install’ and you’ll find a ton of threads and info. Lots of reading to do!
pcskier is offline   Reply With Quote
Old 10-30-2020, 10:47 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
here is what i installed 2 years ago.
Name:	AS22FB- power DC-V13b.jpg
waninae39 is online now   Reply With Quote
Old 10-30-2020, 11:15 PM   #4
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I’ve got two Zamp 90W panels and a Zamp controller on my 23FB, along with AGM batteries. It’s not bad, but I’m adding capacity with a Zamp portable panel. I’m not replacing the AGM batteries at this time.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Dennis C is offline   Reply With Quote
Old 10-31-2020, 09:51 AM   #5
P , California
Thanks. This looks far more complicated than I imagined. So going solar with Lithium Ion batteries involves more than just adding a charge controller?
Old 10-31-2020, 09:52 AM   #6
P , California
Thanks. Where did you find space for two panels?
Old 10-31-2020, 09:55 AM   #7
Dennis C's Avatar
Zamp 90W panels are long and narrow, so they fit the roof of an Airstream very well. My panels are mounted on the forward portion of the roof, one on each side. I could easily fit two or perhaps four additional panels on the roof.
Dennis
Old 10-31-2020, 10:16 AM   #8
2021 23' Globetrotter
Jefferson City , Missouri
2021 Globetrotter 23 FBT
We ordered a 23 FBT with the factory solar. The dealer is going to install a second 90W panel for $750 but ended up throwing it in deal. We are discussing the upgrade from AGM batteries to Lithium. The costs and options are:
2 x Battleborn 100Ah Batteries
Updated converter
$2,800 installed, plus tax
Expion360 Option:
2 x Expion360 100Ah Batteries
Update converter
Same pricing, but the Expion360 battery is a better performing battery in our experience. Battleborn is the recommended battery by AS
The only additional expense ( not doing) would be a shunt with temperature sensor and Bluetooth capabilities (smart phone app). This would allow you to see the charging rate and discharge rate. The cost on that is $528 installed, plus tax.
Dealer has us keeping the AGM's which I will sell as new - trade in was only $50 each!
Jsailmo is offline   Reply With Quote
Old 10-31-2020, 11:07 AM   #9
brookhaven , Georgia
I would think that only having one panel would be limiting. My Interstate came with one panel. Now it has four. If there were room, I would add more.
coasttocoast is offline   Reply With Quote
Old 10-31-2020, 12:24 PM   #10
Toaster Life
2010 23' International
Tucson , Arizona
While rooftop panels sound good, when we camp in the summer we seek out shade which will reduce the efficiency of even the best panels. Rather than add more panels to our rig we added a portable panel with an extra long cord of high gauge wire to minimize resistance, and park in the shade and deploy the portable panel in the sun. In the evening we reposition it to catch the early morning rays, this way we get the best of both worlds, shade for the rig and maximum solar from whichever site we are at, the portable panel works for us. The panel has its own controller and plugs right into a socket on the battery box, for easy connecting and disconnecting. Also roof panels get dusty, which further reduced efficiency, and are a pain to keep clean.
Toasterlife is offline   Reply With Quote
Old 10-31-2020, 02:32 PM   #11
ProTech's Avatar
2017 23' International
Portland , Oregon
No dealer!
If you're taking it to the dealer in the Bay Area, run don't walk. Take it to AM Solar and get a professional solar company to do the work. We started with factory panels and had them add one more, they turned our roof into Swiss cheese. The panels failed with in two years and they took no responsibility for anything.
AM Solar up graded our system with lithium and everything the dealer won't install that your system needs. You will regret any dealer work in the long run.
ProTech is offline   Reply With Quote
Old 10-31-2020, 02:51 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Getting creative and replacing the original crank up TV aerial with a round auto search unit, we were then able to install five 100 watt AM Solar panels on the roof of our 2015 23D International Serenity. We were able to put the 300 amp-hour lithium battery just in front of the tire wheel well street side and under the sofa. In fact, the Magnum MSH-3012 inverter/charger, solar charger and all other system stuff including the added front power inlet with auto transfer switch fit under the sofa/dinette seating with no loss of storage. The pull out for a bed is also operational.
This work, along with replacing the failed factory flooring after driving 2,000 miles from the dealership and custom cabinet work, Truma instant on water heater, Dometic CU-434 stove and Vitrifrigo DP-150L Freon based Dan Foss compressor refrigerator tweaked our 23D to perfection. I had brought 15” SenDel wheels with 15” Michelin tires mounted to replace the stock 14” tires and wheels while adding the reused Hensley Arrow weight distribution hitch and Prodigy RF brake controller.
We had this work done by A&P Vintage Trailer Works in Paradise, TX. They are also authorized to perform Airstream warranty work including replacement aluminum skinning.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Maiden Voyage 2021 Flying Cloud 23FB matthewk Our Community 10 11-23-2020 11:26 AM
2020 versus 2021 International + Factory Solar hobbie1 2016 - Current International 6 10-10-2020 08:26 AM
2021 Stock AGM with Solar upgrade? grumblin Batteries, Univolts, Converters & Inverters 0 08-21-2020 09:57 AM
Caravel 16 2021 and steps to add solar hovr Generators & Solar Power 9 08-04-2020 02:56 PM
Portable Solar for 2018 International 23FB weirdstuff Generators & Solar Power 12 09-12-2017 09:13 PM
