RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-01-2018, 12:14 PM   #1
High Point , North Carolina
Single bat hookup
Say folks, if I wanted to hook a single 12 volt to our '17 FC just to do a water pump quick on off, do I just do both big reds to POS and both big blacks neg, yes? Ignoring all the other connections..?
Rfriebele is offline   Reply With Quote
Old 11-01-2018, 01:20 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Assuming that the big lines go to the inverter and the other lines go to everything else, you probably can get away with the small lines. The gotcha is if you aren't correct in that guess. The easy way to run the water pump is to just plug the 7 pin into the tow vehicle and put it into a mode that it will source power. Equally easy is to plug into shore power with a 15A adapter and let the converter charger supply the system. (note: most converters will do fine, there are a few that will not come on without a battery).
Hi from Bat Cave RichardT Member Introductions 9 04-17-2019 05:32 AM
Bat Cave in the news! RichardT Off Topic Forum 3 05-28-2007 01:58 PM
"What is it?" #3 From Bat Cave RichardT Our Community 18 12-04-2005 08:49 PM
"What is it?" #2 From Bat Cave RichardT Our Community 11 12-04-2005 09:39 AM
New - "What is it?" From Bat Cave RichardT Our Community 13 12-02-2005 12:00 AM
