Old 07-09-2020, 11:08 PM   #1
2020 33' Classic
Sarasota , Florida
Satellite TV Cable Missing
I have a 2020 33 Classic and have discovered that Airstream failed to either run the cable up the wall of forgot to install it all together. Has anyone else had this issue?
Gigler is offline   Reply With Quote
Old 07-10-2020, 04:06 AM   #2
2016 25' Flying Cloud
z , Texas
I believe it runs through the HDMI, and the cable is located behind the DVD player just my 2˘
5150mike is offline   Reply With Quote
Old 07-10-2020, 05:14 AM   #3
2013 30' Flying Cloud
Kingwood , Texas
It’s there, you gotta dig around and it’s normally labeled. I have read where some have been very short, but they finally found it.
DoubleR is online now   Reply With Quote
Old 07-10-2020, 05:29 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you're that short, I'd recommend getting something to stand on while searching.
Seriously, unless it was somebody's first day on the job and they forgot it, it should be there in the rat's nest that is the wiring in that area.
Old 07-10-2020, 10:42 AM   #5
2018 27' Flying Cloud
Atlanta , Georgia
The satellite cable in my 2018 FC comes out from cutout next to DVD player. But to access it for the first time I had to remove the wooden case around the DVD player and reach through hole in the cabinet. It is there but not pulled through at the factory for some reason.
jnm30327 is offline   Reply With Quote
Old 07-10-2020, 10:52 AM   #6
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
SAT cable can be behind the radio
Although the manual states that the cable will be found under the DVD player. That is not always the case.
In my 2016 International Signature I removed the DVD unit, removed the bottom railing of the sliding plexiglass doors to be able to remove the radio side panel (the one with the two 110V wall plugs) to get to the cabling behind the radio. I found the SAT coax cable (labelled SAT) in the nest of cables there.
The cable had two strips of electrical tape leading me to believe that the cable was taped to the rest of the DVD cable harness but broke off when they pulled the harness through the hole in the radio side panel to get to the DVD, resulting in the SAT cable remaining "invisible" behind the radio.
An alternative to removing the plywood panel between the DVD and the radio compartment is to slide the radio out to get to the SAT cable; a techician at Jackson Center showed me how this was done -- any shop that installs car radios can do this in a few seconds (or any car radio thief for that matter...!).
So if you don't find the SAT cable under the DVD player, don't despair, it's probably in the compartment behind the radio.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 07-10-2020, 11:15 AM   #7
2019 33' Classic
Miami , Florida
I had the same problem with my 2019 Classic. I went to Home Depot and purchased a cable tracer. Puts a tone on the cable from outside. Traced it to the middle of the wall below the DVD player. Had to take it to the dealer to take love seat out, remove wall cover, and continue wire up the wall to the DVD player. Sad.
Dog House is offline   Reply With Quote
Old 07-10-2020, 11:51 AM   #8
2020 33' Classic
Sarasota , Florida
Not possible because the coax outside the coach is not an HDMI.
Old 07-10-2020, 11:55 AM   #9
2020 33' Classic
Sarasota , Florida
Thanks. I have taken my AS to two different dealers and they have all called JC to be to told the cable is marked but may have fallen down behind the wall. For the life of me why wouldn’t AS run the cable and install it into a connection jack plate and call it good With the cable tv coax antenna amplifier jack plate. Thanks for your reply.
Old 07-10-2020, 11:56 AM   #10
2020 33' Classic
Sarasota , Florida
It’s not there.
Old 07-10-2020, 11:58 AM   #11
2020 33' Classic
Sarasota , Florida
FC stereos are not the same and neither are the connections which is why I have a Classic .
Old 07-10-2020, 12:36 PM   #12
2019 27' Globetrotter
Salem , Oregon
+ on recommendations from dog house. Get a cable tracer and you will be able to find it. Dave
NoResults is offline   Reply With Quote
Old 07-10-2020, 02:20 PM   #13
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
The model is irrelevant. If your cable is in there, as others have suggested, go get a cable tracer and you will locate it. Fairly simple.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 07-10-2020, 04:16 PM   #14
2008 23' Safari FB SE
2018 27' International
Okemos , Michigan
It should be there
I have a 2018 Intl 27 and believe me that cable was hard to find. Be patient and reach all around in the opening behind Dvd player and you will find it. Just another A/S mystery why they make it so hard.!!!!!!
llhenn is offline   Reply With Quote
Old 07-15-2020, 10:06 PM   #15
Txwildcat
2020 33' Classic
San Antonio , TX
I found it!!!
We have purchased a new Classic 33 FBT. After almost giving up, i found the satellite connection tonight. I have already purchased a line tracer and diplexers if i could not find the cable. i was going to do the old fashion way.
Why not put in a box easy to find.
It is there, but it is behind the the shade wall in a Classic.
Crazy!
Txwildcat99 is offline   Reply With Quote
Old 07-27-2020, 12:04 PM   #16
2020 33' Classic
Sarasota , Florida
Missing Satellite Cable
Crazy!
I visited Airstream Adventures in Oregon and they found the cable on the floor behind the wall behind the couch. What type of satellite dish are you using? I am using a Wingard G3 Carryout. I used it once on my old trailer with no problems. On my AS I dont seem to be getting a signal from the sat dish. After you found your cable did you have to make any other connections or disconnections in order for your system to function?
Old 07-28-2020, 12:26 PM   #17
Txwildcat
2020 33' Classic
San Antonio , TX
I am using a KING KOP4800 One Pro Premium Satellite TV Antenna and Wally receiver.
Once I found the cable, it was easy. I put an HDMI switch in and I am distributing satellite sign to the bedroom.
Satellite coax cable BobAndStella Our Community 5 03-13-2019 04:38 PM
Satellite Cable Source Cispook Computers, Internet & Satellite 2 06-23-2018 08:21 AM
Can't find satellite cable inside AS Scomor Our Community 2 12-11-2016 02:36 PM
Cable TV/ Satellite Receiver Dual Coax Face Plate pwesterman 2008 Safari SE 2 11-14-2010 01:09 PM
Satellite TV AND Radio, Theatre-like Sound, Cable, iPod, and Bluetooth all in one!!! 78GussyTX Audio, Video & TV 12 11-12-2008 09:36 PM
