RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-12-2017, 03:31 PM   #1
Mobilephotog's Avatar
1973 31' Sovereign
Fryeburg , Maine
Power loss
New to rv' s and Airstream's
I just purchased a 1973 landyacht I plugged in shore power and everything worked fine all the interior lights and AC. All of a sudden the lights went out. The AC still works.
Maybe a simple newbie question. What happened. Any ideas where I should look
Jeff
Mobilephotog is offline   Reply With Quote
Old 08-12-2017, 03:33 PM   #2
Long Island , New York
Welcome to the forum and Airstream community!
Look for the main 120-volt circuit breakers, per the location spec'd in your owner's manual. Probably in the front or back of the trailer somewhere.
The lights that went out are probably 12-volt lights, which means you should also look for the 12-volt circuit breakers, which may reset automatically. Do your other 12-volt devices work, like the water pump?
It is possible that your converter (which turns 120 volts AC into 12 volts DC, and charges the batteries) just burned out IMO. If the converter is bad, and your batteries are also bad, or very low, you will not have any 12-volt items functioning normally, but the air conditioner, and 120-volt plugs will still work. The 12-volt distribution panel and circuit breakers can also be located via the owner's manual.
Please plug in a 120-volt appliance like a simple light, or toaster, etc., to see if the outlets work. If they do, and the A/C is still working, at least you have shore power in the trailer.
If you don't have an owner's manual, one can be located online if needed. Please advise.
Good luck!
Peter
PS -- This Sovereign sub-forum may be another good place to ask about locating things in your 1973 31' FYI:
http://www.airforums.com/forums/f186/
Old 08-12-2017, 03:47 PM   #3
1973 31' Sovereign
Fryeburg , Maine
Thank you
Old 08-12-2017, 03:57 PM   #4
1973 31' Sovereign
Fryeburg , Maine
Thanks I just checked the 110 outlets and they work next up find 12 volt fuses
Old 08-13-2017, 05:59 AM   #5
Noticed your new post in the Sovereign sub-forum:
http://www.airforums.com/forums/f186...ss-171315.html
Good luck!
Peter
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 09:57 AM
Loss of DC electric power stevedeiwert Electrical - Systems, Generators, Batteries & Solar 8 07-24-2011 10:11 AM
HELP...Sudden loss of power to AC netlace Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-09-2011 07:28 PM
Power Loss The Flintstones Electrical - Systems, Generators, Batteries & Solar 9 10-09-2006 08:27 AM
12V power loss sladew Electrical - Systems, Generators, Batteries & Solar 2 08-05-2003 05:47 PM
