07-21-2017, 07:17 PM
1993 34' Excella
Estancia
, New Mexico
No tv air signal?
I am trying to get an over the air signal at Coeur d'Alene. Yesterday got 6 weak signals, now 0. Winegard batwing in my 93 is amplified. I suspect a sudden amplifier failure. Also failed when I turned on an interior 120 light. Thoughts. Ideas. Any way to test?
07-21-2017, 08:18 PM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
Is the amp still getting power?
07-21-2017, 08:56 PM
1993 34' Excella
Estancia
, New Mexico
Hi
When I turn on the little wall switch the red light comes on.
07-22-2017, 12:31 AM
1986 31' Sovereign
Miami
Got a Fantastic Fan running near the antenna? That could wipe out a weak signal...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
07-22-2017, 07:23 AM
1993 34' Excella
Estancia
, New Mexico
93 oem fan. Not running. No previous interferance. Had 6 channels earlier, now 0. Not even a weak channel.
07-22-2017, 08:52 AM
1982 31' Airstream 310
champaign
We had the same thing happen a couple weeks ago. Started looking at all the connectors, my signal amplifier is inside the wall but not too bad to get to. My problem was one of the F connectors had broken, it looked ok at a glance but when I moved it..it came apart. Got a new crimp on connector and everything is fine. Hope yours is as simple.
07-22-2017, 04:35 PM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
If it's not an F connector, next thing to check is the DC injector. A multimeter will show you if it is putting voltage on the coax to the antenna. If it's still sourcing DC and the connectors are ok .... Start poking at the antenna. It may be the amp.
07-23-2017, 08:58 AM
1993 34' Excella
Estancia
, New Mexico
I unscrewed the unit and wiggled it. Now it works. Don't know exactly why or how.
07-23-2017, 09:43 AM
2007 22' International CCD
Corona
Sometimes the connectors get some corrosion or shake loose. That's why wiggling and re-seating connections of any sort is the first troubleshooting step.
It can be quite subtle
07-23-2017, 12:42 PM
Lexington
, Kentucky
You can get/use something called 'tuner cleaner', used to be used for the old rotary channel selector on TVs. Still sold by that name or electronics cleaner. It's very handy to have in your toolbox. I got a small can from Radio Shack and a larger one from somewhere else, maybe Amazon. It cleans the contacts and evaporates, no / little residue, unlike WD40 which is a penetrating, lightweight oil.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
