Old 06-23-2019, 02:37 PM   #1
Silvr_Bullet's Avatar
42 2' 27" N / 74 7' 6" W , US
No Solar Power
If someone can help with this it would be great. I have a roof mounted solar panel, I zeroed out all the solar statistics from the display a few days ago its been sunny the last two days my panel is not in direct sunlight but always registered some charging of the battery ( I also have 120V hooked up ) there is -0- solar amps either accumulated or charge registering. I checked the connections on the house battery and the fuse, seems ok. Is there any other things I should be checking? Thanks for the help. I also washed the solar panel.
Silvr_Bullet is offline   Reply With Quote
Old 06-23-2019, 06:13 PM   #2
Its working now I think its a loose wire in the SunPlex display
« Unknown TPMS | Top | Sat »
Solar Power- Pauper Power Charging Ray Eklund Boondocking 65 06-03-2020 09:07 AM
Renogy, Am Solar, Grape Solar, Go Power what's the best or what are you running?why? ASTailgate Electrical - Systems, Generators, Batteries & Solar 28 06-14-2017 11:30 PM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 07:11 PM
