RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-24-2018, 07:48 PM   #1
2013 25' International
Boise , Idaho
Jack not working, no ground
Hi all,
The other day I was moving the trailer and found my Barker jack to be dead. I messed with it a bit, but didn't have the time to properly test it. Today, I tested things and found the cause to be poor grounding. The barker jack relies on the internal connecting to the a-frame to ground, but my this isn't working for me. If I jumper the ground to a ground post on the battery or an unpainted spot on the frame, the jack works. Looking at where the mount bolts to the a frame, I can definitely see some gaps but the nuts are very tight and the connection is excellent.
Rather than taking off the jack, sanding through pain and resetting, I'm wondering if there would be any downside in simply running a ground wire from the switches to a proper ground where my remote terminals will go. I like using the bolts to ground the jack but I also don't want to futz with it more in the future if I don't get it just so.
Thoughts?
Thanks!
Adam
afk314 is offline   Reply With Quote
Old 02-25-2018, 08:31 AM   #2
2016 30' International
Florence , Alabama
Should be fine just use the same size wire or bigger than the positive.
joshjack is offline   Reply With Quote
Old 02-25-2018, 09:16 AM   #3
Mollysdad's Avatar
Okay. The jack positive is a black wire with a yellow ring crimp.
If you run a ground wire I'd take it to the OTHER negative so you are flowing through both batteries.
However, just for fun, I'd try a star washer first. The bolts are 3/16, and star washers are designed to cut through paint, etc.
Old 02-25-2018, 08:55 PM   #4
Boise , Idaho
Star Washers
Never knew about them but I think I will give them a shot. Thanks for the help.
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 12:25 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Power Jack/Control panel not working TinLiz Towing, Tow Vehicles & Hitches 5 06-27-2012 12:41 PM
Electric Jack Not Working eberrobw Jacks, Stabilizers, Lifting and Leveling 13 03-14-2012 12:23 AM
Elec Stab Jack Not working Coloradoair Jacks, Stabilizers, Lifting and Leveling 22 03-16-2011 12:42 AM
