Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 04-08-2021, 01:33 PM   #1
AirstreamCSH's Avatar
2022 27' Globetrotter
Asheville , North Carolina
(Install) weBoost Cellular Signal Booster
This is a post for general reference for anyone interested in installing a cellular booster in their Airstream travel trailer but might be unsure of where to begin. For most of us, the big concern is drilling a hole in the roof and not creating future leak nightmare and/or accidentally hitting some hidden wire, support, etc. What follows is what we did on our 2016 Flying Cloud 25FB. YMMV
FIRST:
There are many options to choose from in considering a cellular booster and this post isn't meant to be a study of what to buy but of how we installed it. Prior positive experience predisposed us to select the weBoost line from Wilson Amplifiers. In specific, we chose the Drive X OTR Fleet Signal Booster Kit for the travel trailer because by mounting the antenna on the roof, we felt that the height and the metal plane of the roof would give us results equal to what the more expensive Drive Reach version would provide. For the F250, the Drive Reach was used because the antenna was mounted much lower, just over the driver side fender.
SECOND:
We do our own maintenance and upgrades whenever practicable because when you get stuck at a campground with a burnt-out hot water heater ignition board, or the thermostat wire to the heat pup is grounding out, its more comforting to us to be able to fix the problem ourselves instead of being reliant on others to help us at a time and place of their choosing. That said, when the large drivers side window shattered, it was Dallas Airstream who put it all back together again because for some things, there is no substitute for kind, knowledgeable dealer repair expertise. I point this out only to give you a reference point to whether or not the information posted here is worth paying attention to. For example, we did our own 450w solar installation among other projects.
THIRD:
In our unit, the best place to bring the wire down from the roof was through the closet adjacent to the shower. We knew from taking apart the light fixture and poking around with a light through the return duct vent in the main hall that there were no wires or systems we would accidentally cut if we drilled through the closet. We drilled up from inside the closet through the roof using a 3/8" metal drill bit. This size was chosen because it fit the 3/8" rubber grommet that we used to protect the RG6 wilson cable from chafing against the cut metal. Anytime we wire through a moving object, we use a simple grommet like you see in the photo below.
FOURTH:
To completely seal the roof penetration while giving future ability to change the cable should it get damaged or to simply upgrade the system in the future, we used a Scanstrut DS21A-S stainless steel cable seal with rubber compression cable glands. The benefit of this method is we have a metal fitting that won't break down under UV rays or otherwise get compromised mechanically while having a UV stable weatherproof seal around the cable that can be easily removed and replaced in the future. A grommet was inserted into the roof hole, the Scanstrut then slid onto the cable and the cable itself was passed through the roof grommet into the closet area below. The base of the ScanStrut was screwed into the roof of the Airstream using the provided screws. Excess cable was tied to the roof using a cable mount with 3M VHB. Once the interior cable was secured inside and attached to the Wilson Amplifier, Sikafkex 291 Fast Cure Marine Adhesive was squirted inside the ScanStrut above the grommet and then around the exterior of the ScanStrut between the stainless steel housing of the cable seal and the Airstream white aluminum roof. The ScanStrut was then mechanically brought under pressure using the 3 screws provided thus sealing the rubber of the gland around the cable.
FOURTH:
The hard part having been completed, we routed the cable over the top of the shower and installed the weBoost amplifier on the wall just above the TV taking advantage of the proximity to the electrical outlet. We have both 12v and 120v adapters for the booster so we can run it while plugged into shore power and while boondocking which is how it is usually used.
Hopefully this helps the next person thinking about this install.
Name:	weBoost Drive X Roof Antenna Install - FC25FB Airstream.jpg
ID:	392758   Click image for larger version
Name:	weBoost Drive X Closet Cable Install - FC25FB Airstream.jpg
AirstreamCSH is offline   Reply With Quote
Old 05-12-2021, 08:46 PM   #2
2021 27' Globetrotter
Half Moon Bay , CA
Hi, thanks for this detailed walkthru. I like the sound of those Scanstruts. How did you secure the antenna to the roof? I'm hoping to do something similar...
Aegean-Blue is offline   Reply With Quote
Old 05-12-2021, 11:31 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
Nice job! Thanks for the tutorial on the install.
Now that you have used the two weBoost, Drive X OTR and the Drive Reach. Have you tried them in some remote areas yet? How would you compare there performance? Does the X OTR on the trailer perform as well as the Reach on the truck parked at the same location?
-Dennis
batman is offline   Reply With Quote
Old 05-15-2021, 06:09 AM   #4
Roof Mount
Since we already had solar panels on the roof, we drilled a hole in the aluminum panel support on side closest to the trailer edge as it curves down. Mounted the antenna at an angle to keep it just below the height of the AC.
Will post a photo when I’m near a PC.
Old 05-15-2021, 06:14 AM   #5
-Dennis
After installing, we drove 12,000 miles through remote NV, CO, NC, TN and several other statues. The truck Reach unit consistently had a higher boost level than the trailer but for our purposes, the trailer was just fine. When I have another $500 or so unaccounted for, I’ll upgrade the trailer unit. It could be that the Reach unit is better or that the trailer unit was already 3 years old. The trailer unit is mounted 3’ higher at a 45 degree angle to the metal roof plane. I plan to test it in a fully vertical position to see if that matters.
The last time I made this run, we couldn’t get any internet access at all in certain places and on certain roads. This time, we had at least one bar the entire trip except for one extremely low spot in a valley. For us, it was worth the cost and effort as we work from the trailer and need the signal.
Old 05-15-2021, 06:27 AM   #6
batman's Avatar
1964 22' Safari
Thank you! That is good info, I appreciate it.
-Dennis
Old 07-09-2021, 02:00 PM   #7
2019 27' Tommy Bahama
Nice post! Thanks for the detailed information. I’m very curious about your external antenna location choice
1) Are you at all concerned about the shadow it may cast on your solar panel?
2) Is the actual antenna portion above the AC units (when deployed) so it has 360-blue sky view? Does that matter?
3) Was there any thought to mounting it to an extending pole at the front of the trailer that could extend much higher upward? Would that have boosted performance, or would the additional length of cable run zeroed out the performance gain?
Thanks VERY much for sharing your results!!!
Mark of SJC is offline   Reply With Quote
Old 07-09-2021, 07:32 PM   #8
2017 25' International
West Lake Hills , Texas
Perfectly timed post for me. Just about to order and install one. We, too, like to do our own maintenance and for the same reasons. Thanks for the detailed post.
Fungus is offline   Reply With Quote
Old 02-13-2022, 05:48 AM   #9
Sorry for the delay - just saw this.
1) Yes but not really. 450 is overkill for our battery bank 220ah so I preferred to have one less mounting point.
2) No. it sits just below the AC horizon.
3) I did that 2 yrs prior. What a pain in real usage. Often just didn’t bother to do the whole install each time. This way it was already in place.
Old 02-13-2022, 06:18 AM   #10
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
I also installed a WeBoost system in our AS, and also in the closet beside the shower.
But we have a 28 foot model and the grey tank vent pipe runs though that closet and exits the roof. It was a fairly simple matter to drill holes in that pipe on both sides of the roof and run the cable that way, with only about 6" going through the vent pipe before exiting in the closet.
I sealed it, but if a bit of water seeps in it'll just run down into the grey water tank.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 03-07-2022, 11:52 AM   #11
2015 25' FB Flying Cloud
Palmetto , GA
Nicely done by the original poster. The mounting issue with the WeBoost RV 'beer can' was solved by his having a solar mounting frame. I see from the photo he still has the weak TV antenna. I'm replacing the same TV antenna on our 2015 25' FB [on ours, mounted in the middle in front of the a/c] with the Winegard Sensar IV amplified antenna, and am planning to strap the WeBoost RV antenna [prior owner installed the WeBoost cel booster, but with a lesser external antenna you have to mount at each stop ....]. Depending on the placement of the Sensar IV mount, I plan to run the cables [coax for the Sensar and from the WeBoost RV antenna] through a marine plastic cable cap/gland, likely using the old antenna's hole in the roof if I have to locate the big [16" wide] Sensar further forward with a new hole. Anyone have tips on mounting the WeBoost RV to Sensar's elevator tubes? I'm thinking flat galvanized strapping around one of the elevator tubes.
RxDiesel is offline   Reply With Quote
DIY Motorized Antenna Mount for WeBoost Cellular Booster on a FC 2018 MandN Electronics & Connectivity 1 08-30-2020 12:48 PM
WeBoost Cellular Signal Booster grwalk Airstream Classifieds 2 11-13-2019 06:02 PM
weBoost Drive Sleek (Cell Phone Signal Booster) TayaraTravel Sprinter and B-van Forum 45 11-28-2018 02:38 PM
Weboost cellular installation Gamehawkers On The Road... 2 01-03-2017 11:17 PM
