RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-02-2018, 10:14 PM   #1
2008 27' Safari FB SE
Phoenix , Arizona
Install rear view safety wired system on Safari SE 27FB
Just purchased system from Costco. Wired system To Ram. What is best location for camera if it high above rear window, what is best way to run wire. Thought about over license plate but have read posts about glare from headlights. Thinking about using anodized aluminum cable tray with silicone and filling joints and running at window head.
Any recommendations?
Nice system. Commercial grade. Three cables for tow vechilce joint and trailer.
Gman88188 is offline   Reply With Quote
Old 03-03-2018, 05:47 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forum.
Why not mount the camera inside at the lower edge of the top of the window?
Old 05-06-2018, 03:28 PM   #3
2016 26' Flying Cloud
Spooner , Wisconsin
I have a 2016 model that has several USB outlets around the interior. One is located near the rear window. As far as I can tell, the wires to the USB are 12VDC. I tapped those wires to power my rearview camera. That way you do not have to have your car lights on to power the camera. I installed a little in-line switch to the camera and only hve to remember to turn it on and off. Or not. If you are on shore power, it doesn't matter.
It works fine. I elected to mount camera on the outside and threaded the wires out through the slit through which the window opening struts pass. At that point you could choose to mount the camera between the screen and the glass or just above the window.
My additional suggestion is to mount the camera dead-center. The one in my RAM 1500 is a little off center and at times makes backing into a target difficult.
Regards,
WherryWillie is offline   Reply With Quote
Old 07-27-2018, 12:26 AM   #4
2014 23' Flying Cloud
Albany , Oregon
Anodized aluminum tray?
So after 4 months, you probably got this system up and running.
I want to do the same installation, running the 5 wire cable from back of AS to the tongue. Where do I find "anodized aluminum cable tray?"
Someone { I can't find who/when} suggested going under the plastic trim strip between the top and bottom shells. Cool, but, how?
kiltdaddy is offline   Reply With Quote
Old 07-27-2018, 09:27 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
mount as high up ABOVE the windows as you can.
the higher gives better depth perceptions when in the TV
our in the 22FB is just below the airstream lettering
waninae39 is offline   Reply With Quote
Old 07-27-2018, 09:37 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Used Velcro... I don't do holes in the skin if not needed. 😂
Wired thru window weatherstrip to the rear 12v powerport, with a switched plug.👍
ID:	318208   Click image for larger version
ID:	318210   Click image for larger version
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
ROBERT CROSS is online now   Reply With Quote
12V System Pre-wired for Accessories Burnside Bob Electrical - Systems, Generators, Batteries & Solar 0 09-27-2015 12:04 AM
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 06:01 PM
Rear View Safety-quad system cwf Tow Vehicles 10 05-05-2013 06:07 PM
View from your rear view mirror.... valmog On The Road... 2 08-23-2011 11:20 PM
