Old 05-13-2020, 01:13 PM   #1
Tyrinius's Avatar
2009 30' SO Classic
Alexander City , Alabama
Haloview RD10
Does anyone have experience with Haloview’s new product the RD10? I performed a search on the forums with no results and it appears buying from Haloview directly is the only option at this time as Amazon does not seem to have them available. I like the ability to mount it directly onto the rearview mirror. It has a forward dash cam that’s 1080p and the rear cam is 720.
~ 2009 30' Classic SO ~
~ 2018 Ford F-250 Lariat 4x4 6.7L Turbo Diesel, Diamondback HD Truck Cover ~
Victron 3000W MultiPlus, BMV 712, 100/50 SmartSolar, 600W Renogy, BattleBorn Lithium
MicroAir Soft starters, SeeLevel Tank monitor, Maxim Skylights
~ Slide Out Society #089 ~
Tyrinius is offline   Reply With Quote
Old 05-13-2020, 01:29 PM   #2
skitger's Avatar
2022 25' Flying Cloud
2018 16' Sport
1962 22' Safari
Corvallis , Oregon
Check with GMFL, he has tested some of the Halo products, Rick
Rick & Paula LaMont
2022 Flying Cloud 25’ FBQ
WBCCI #7944
skitger is offline   Reply With Quote
Old 05-13-2020, 01:45 PM   #3
Tyrinius's Avatar
2009 30' SO Classic
Thanks Rick. GMFL (so cutting edge that guy ) actually introduced me to this particular model and a YouTube video by Love Your RV. Maybe it’s so new, ordering directly is the only way to go at this time.
Old 05-26-2020, 12:50 PM   #4
Tyrinius's Avatar
2009 30' SO Classic
I placed my order today on the RD10. Anyone with one installed? GMFL was kind enough to let me test fit one with my rear view mirror. I must say it was an excellent fit and it doesn’t restrict your view as a regular 7” monitor would.
Old 07-02-2020, 06:03 AM   #5
2017 25' Flying Cloud
Midland , Michigan
Did you ever install this? I’m interested in this camera setup. Do you like it and how did the install go?
azeeb is offline   Reply With Quote
Old 07-02-2020, 06:57 AM   #6
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I installed it with a Tyrinius and have installed one other with jayseejay.
It’s a very nice system.
One special note..... THIS SYSTEM MONITOR RUNS OFF 5v DC so you CANNOT hardwire it directly into your system or up fitter switch. (Dot ask me how I found this out......)
The “12V” accessory plug has a step down transformer in it.
The camera is 12V so it is fine to power from the trailers clearance light.
Other than than small issue it’s a GREAT system.
Old 07-02-2020, 05:57 PM   #7
Midland , Michigan
Thanks. My airstream is a 2017 with the voyager camera preinstalled. I was thinking of switching to this unit just to avoid having the huge voyager display on my windshield. This mirror mount display seems like a much cleaner setup,
Do you happen to know if the camera with the rd10 would fit into the voyager camera bracket that comes preinstalled in later model airstreams? That would make the install very easy. I’m just not sure how the camera mounts or if it has screw holes that line up with the existing voyager bracket.
Old 07-04-2020, 07:31 AM   #8
Tyrinius's Avatar
2009 30' SO Classic
Thanks for responding for me GMFL, my cell service has been vey limited the last several days here in GTNP. I am very happy with the setup. One thing to note: I drive a 2018 F-250 and the dash camera has a slide to give it some flexibility, but the view is still partially blocked on the right side by the black cover behind the rearview mirror on my truck. Maybe something to think about, but if you don’t have any obstructions behind your mirror then no worries. The display will definitely not be in your way. The signal strength is excellent. I don’t even use the antennae made for the display, only the one on the trailer mounted receiver.
Old 07-04-2020, 07:39 AM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
The camera will not fit the bracket.
