Old 01-29-2024, 04:52 AM   #1
2023 19' Bambi
Oly , Washington
Grounding: EE's opinion(s)?
I have done a LOT of electrical rework on my '23 19' Bambi, thus far I have always considered the negative bus to also be ground.
I'm installing a POE injector that speficically states the case must be gounded to prevent static build up, this got me thinking: IS using the negative bus as ground correct? It's not like I can drive a 6' copper pole into the ground for a 'true' ground! Would grounding to the chassis be more correct?
Thanks in advance!
saltbreez is offline   Reply With Quote
Old 01-29-2024, 05:04 AM   #2
dznf0g's Avatar
Oswego , Illinois
In my opinion, since the buss is grounded to the chassis, it matters not. I ground required grounded chassis components to the buss. But I'm not an EE.
-Rich-
Old 03-25-2024, 02:38 PM   #3
2021 20' Basecamp
San jose , California
The negative bus is grounded to frame in my my trailer on the DC side, and then the AC is grounded to the frame as well. My unit has just a bare copper 12awg wire as the bond to frame. As long as that is done, should be good, only concern would be the wire gauge being too small for an inverter that shorts to ground.
Hn387 is offline   Reply With Quote
Old 03-25-2024, 05:14 PM   #4
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
The bond should be sized (at a minimum) to the largest circuit.
Brian
ITSNO60 is offline   Reply With Quote
Grounding Copper gas line slk LP Gas, Piping, Tanks & Regulators 11 06-30-2009 04:33 PM
LED Marker light grounding. briheath Lights - Interior & Exterior 13 05-31-2009 07:33 PM
Electrical grounding problem with AC hook up Mr. D Mechanics Corner - Engines, Transmission & More... 3 09-02-2008 04:20 PM
generator grounding JK3500 Generators & Solar Power 23 06-19-2007 03:59 PM
Proper Grounding of 120V input PhilMateo Electrical - Systems, Generators, Batteries & Solar 24 05-11-2006 07:07 PM
