Originally Posted by richard5933
Your Airstream should have reverse lights, and the camera should come on whenever the reverse (backup) lights have power.
The FC 26 does not have back up lights.
However, digging a bit further, Things like "comes on in reverse" have wiring to 'trigger wires'. In other words, power comes through a switch wired to your "R" on the fuse panel.
It should be doable to undo that wiring and instead power the camera from the running lights, or as I did, leave the camera powered all the time. (I have the 770 Garmin with a wireless camera) You should be able to select a camera/map icon on the Garmin.
My setup is a bit different as I have the BC-30 (bluetooth) mounted inside the rear window. I just lay the transmitter on the bed. I have never had any connectivity issues, and I can drive away to about 75' before I lose the signal. I couldn't tell if the BC-20 is bluetooth although the transmitter looks the same. I don't know what the other module is for.
So, for power I simply took one of the USB plugs and changed it to
12v to accommodate the cigarette lighter plug I put on the camera/transmitter.
It works great.......except the resolution is lousy. The BC-30 is only 295 lines so in low light it looks like a bad VHS copy.
I'm keeping the mount and changing to a Haloview camera. (720P)
