RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-09-2020, 03:09 PM   #1
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Front Control Board Replacement
Looking to replace my control panel. Anyone have a contact for a supplier or do I need to just start calling dealers trying to locate one?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 05-09-2020, 09:35 PM   #2
Sparr's Avatar
Casa Grande , Arizona
Call Firefly at (574) 825-4600 and ask for a replacement.
Steven & Lisa
"Olivia" 2017 Airstream Classic 30
2016 Dodge Ram Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
WBAC (WBCCI) Region 11 1st VP - Life Members # 5523, AIR # 118556, KJ6DKF
Sparr is offline   Reply With Quote
Old 05-11-2020, 10:05 AM   #3
2018 30' Classic
Ouch. $200 board.
Turn around time is nice though. They make the boards per order and it takes about 2 days to produce and ship. Should get the new panel before the weekend.
This is a good number to save for anyone with firefly. Very helpful staff too.
BigSxyWhtGuy
Old 05-11-2020, 04:42 PM   #4
2018 30' Classic
Williamsburg , VA
May I ask what exactly was wrong with yours?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 05-11-2020, 06:26 PM   #5
2018 30' Classic
I had a water accident. Panel got wet and when you press a button something else would turn on. Awning deployed randomly too. Figured it would be better to replace the board for $200 than to risk the awning deploying while we are driving.
BigSxyWhtGuy
Old 05-11-2020, 06:45 PM   #6
2007 22' International CCD
Just as a final try, soak the entire board assembly in store-bought distilled water a couple times, fully submerged and swishing it around, shaking it off well when changing the water after 20 minutes of sloshing it around. Blow the excess water out with canned air or low pressure compressed air, 20 pounds max. Then dry it out gently but thoroughly in a warm oven, as low as you can set it for a couple hours or more.
See if it now works, then save it as an emergency spare. If there are no batteries or obvious corrosion on the board this old trick can work surprisingly well. If not, you’re just out the cost of a bottle of distilled water.
Last time I tried it the hardware had been sprayed with salt water. It recovered to be even better than new, but the owner darn near had a heart attack when I dumped his expensive photo lab meter in 5 gallons of distilled water!
rmkrum is online now   Reply With Quote
Old 05-12-2020, 07:59 AM   #7
2018 30' Classic
RV oven only gets as low as 250. Won’t that bake the board and melt the plastic?
BigSxyWhtGuy
Old 05-12-2020, 11:11 AM   #8
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Just dry it with a hairdryer set on low heat. This is a patience exercise.
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
Froglips is offline   Reply With Quote
Old 05-12-2020, 11:53 AM   #9
2018 30' Classic
Does the heat matter? I did put out one of those turbo floor fan deals (used to dry carpet) and set up the board to be in front of the air flow for 48 hours. Just reset everything, board still is kinda wonky. It all lights up as normal but when I hit a button it will also turn on another light system.
BigSxyWhtGuy
Replace refrigerator board with a Dinosaur board bigredandoldblue General Repair Forum 0 04-05-2020 02:54 PM
Airstream creates RV owner board to guide brand Airstream creates RV owner board. PecanMan5 Airstream Lifestyle 2 03-07-2019 07:48 PM
Replacement for Suburban 232613 furnace control board redthies Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-05-2016 06:31 PM
Need replacement control board for my Avion 1985 25H stevealbrech Vintage Kin 2 03-19-2014 07:56 PM
Dometic Penguin A/C Control Panel Board Saigon Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-05-2004 11:55 AM
