RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-12-2017, 05:13 PM   #1
2015 25' FB Flying Cloud
Minnetrista , MN
Fishing
(sorry if this is a duplicate but I don't think my first version was posted)
I recently purchased the WeBoost 4G-X RV cell phone booster and want to fish the antenna cable through the refrigerator vent on my 2015 25FB. I’ve seen some posts but I have a couple of questions.
My first choice would be to drill a hole through the side of vent stack (see picture) but I don’t know if that will work. Is it a double wall stack? Is there direct access to the space behind the frig so that I can get the wire into the space behind the frig? Does anyone see problems with this solution?
My second choice would be to drill a hole through the top of the cover and through the screen to get access to dropping the cable down the vent. I would then put a patch on the cover and run the cable out the side by the stack.
My third and least desirable option is to drill out the rivets on the cover and access it in that way. I haven’t worked with rivets before and I’m hesitant to take the cover off even though that would probably give the best access.
There is a cabinet just above the frig and the unit would be installed in the cabinet or on the wall by the TV.
Finally, I would appreciate any solutions to attaching the antenna. I don’t currently have a crank up antenna to attach it to. I need some type of bracket to attach to the top of the AS. Will Dicor alone bond well enough to hold a bracket or do I need to screw it into the roof.
Thanks for the help.
Wesair is offline   Reply With Quote
Old 07-12-2017, 05:16 PM   #2
Minnetrista , MN
Sorry, here is the picture of where I want to drill the hole.
New Fly Fishing Couple from Arkansas Dry Fly Member Introductions 15 05-06-2016 09:30 PM
fishing in Alaska or non fishing baylito99 On The Road... 11 06-24-2012 08:25 PM
Obsession with fishing yukionna The Pet Forum 17 05-12-2006 06:51 PM
NE Fishing Festival 3/23 - 3/26 yukionna Off Topic Forum 0 03-23-2006 07:21 AM
Any surf fishing Airstreamers out there? DPMacV On The Road... 3 04-21-2005 08:29 PM
