RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-22-2020, 05:05 PM   #1
2010 22' Sport
Boise , Idaho
Converter is loose
We recently returned from camping in our 2010 Sport 22. I immediately noticed that the converter box, which in this model rests on the floor below the fridge, was loose. The left side of the box was away from the cabinet by about an inch, while the right side of the box is tight against the cabinet. I opened the drop down converter cover hoping to see a loose screw that just needed to be tightened, but there isn't anything obviously loose. Other than stuffing a wood shim between the converter and the floor how do I go about reattaching the converter to the cabinet?
baldwin6601 is offline   Reply With Quote
Old 08-22-2020, 11:40 PM   #2
2018 25' International
Slidell , Louisiana
The power center / converter frame has the mounting screws and they are concealed by the front drop down cover and the inner breaker and fuse area cover so you have to first remove them to expose the frame, but at that point the 120v bus and wire ends will be exposed so you should shut off power first.
New converter, batteries test good, without charger I loose power? MissingLink5 Electrical - Systems, Generators, Batteries & Solar 13 02-11-2020 09:23 AM
2017 converter vs. 2018 converter. Mollysdad Batteries, Univolts, Converters & Inverters 14 06-01-2018 07:11 PM
Changing out converter to an inverter/converter combo Aaron-Laura Electrical - Systems, Generators, Batteries & Solar 10 10-09-2017 09:18 AM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 03:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 03:59 PM
