Old 09-14-2019, 10:31 AM   #1
barnlight's Avatar
2020 25' Globetrotter
Bend , Oregon
Connecting Wally SAT Box in 2020 Globetrotter.
ID:	352144Click image for larger version
ID:	352145Click image for larger version
I am trying to hook up my Wally Dish receiver inside the 2020 Globetrotter. Other forums say the Sat Cable is inside by blue ray. I cannot find a loose sat cable. I have included pics of what I see. Any recommendations on how to do this?
Thanks, Bryan
barnlight is offline   Reply With Quote
Old 09-14-2019, 10:57 AM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Originally Posted by barnlight View Post
Attachment 352144Attachment 352145Attachment 352146
Thanks, Bryan
Yep! Start taking things apart. I see there is a speaker cabinet door nearby, open it and look for the cable. I swear they hide them sometimes! Mine was halfway down the wall next to the TV cabinet (Classic30).
You've taken the BluRay player box out I assume? Most of the time it is under there.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 09-14-2019, 05:01 PM   #3
2019 27' Globetrotter
Salem , Oregon
My 2019 Globetrotter in FB Twin. The sat cable is located in the wall behind the cabinet that houses the blue ray. Player.
Remove blue ray and you will find panel is held in with three screws you should be able to reach in and pull cable out. I can send pictures or post pictures if you like. Dave
NoResults is offline   Reply With Quote
Old 09-15-2019, 08:18 AM   #4
barnlight's Avatar
Bend , Oregon
Finally Found SAT Cable
I finally found the SAT Cable. I had to completely remove the box where the Blue Ray was and then open the side compartment where the speaker is. It was laying in there. I guess Airstream wants to make you work to hook up Satellite.
Was hoping the Wally would fit where the Blue Ray was, but the cutout is too small. I will have to make some modifications. Thanks for everyone's help.
Bryan
Old 09-15-2019, 11:41 AM   #5
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
FC27 Wally Install
Here is how I did mine. I purchased a 4input-2output HDMI box from Amazon (found on another thread) thought about ditching the DVD/bluray but found with a little wood work I could fit the HDMI box on top with velcro and then mounted my Wally and Apple TV on top. Made a strap to hold those two devices in-place and works well. The RF remotes make all the difference I just keep forgetting to turn on the HDMI box. OH and I added a 2 to 6 electrical outlet to handle the four devices. I found several different ideas here in the forums and this is my version. YMMV
ID:	352200   Click image for larger version
Rick #28279
cptdzl is offline   Reply With Quote
Old 01-04-2021, 10:05 AM   #6
2020 33' Classic
Sedalia , Colorado
I have a 2020 Classic 33'. Using a Dish Playmaker and Walley. I will second that . . . Airstream did not make it easy to find. Thanks to this forum and then a call to Airstream headquarters technical support, it was confirmed that there is a Sat cable that is supposed to be under the DVD player cabinet. Mine was not . . . and Airstream told me I needed to go to a dealer to find it. Instead I went to HD and bought one of those contractor cameras. After 90 mins of looking everywhere, I found it coming out of the hole to the right of the projector behind the curtain housing. It was only five inches long and was running the opposite direction. Without the camera I would have never located it . . . I had to buy a 3ft coax cable and an F Splice connector and Bam . . . I now have Satellite. No thanks to Airstream.
Pastorius is offline   Reply With Quote
Old 04-27-2021, 03:56 PM   #7
2019 25' Flying Cloud
Roodhouse , Illinois
how about hooking up data booster using sat cable outside...what do i do with wally then?
Carla Wise is offline   Reply With Quote
Old 04-30-2021, 06:43 PM   #8
cptdzl's Avatar
Erie , Pennsylvania
My next project
From my reading on the forums I would use the CABLE input.
1 I don't use campground cable (I boondock as much as possible)
2 I prefer my DISH subscription as long as I have a sky view and use the SAT input regularly.
3 other wise I stream through my apple TV
I found my cable "CABLE INPUT" when working under the wardrobe and would maybe? splice into that? and then wiring my booster from there?
Hence my signature....
Rick #28279
Old 04-30-2021, 07:48 PM   #9
2022 Atlas
Homosassa , Florida
On my 2019 FC I use Sat input. I had Dish installer give me a 12"cable to add to the one behind the blue ray.
Tater is offline   Reply With Quote
Old 05-01-2021, 09:38 AM   #10
I have the Flying Cloud 25 ft twin. I found sat cable and used it for booster. But, will try to find cable input for booster and set up wally on sat cable. Thank you. Any advice on where to find Cable input? I guess behind radio.
Old 07-24-2021, 11:05 AM   #11
2021 30' Globetrotter
Oviedo , Florida
Found this thread after I’d found the sat cable. On my 2021 Globetrotter I had to:
Remove the flip up cabinet door
Unscrew the two screws holding the AV box in place
Remove the three screws that hold the triangular panel in behind the speaker
Look in the dark and find the sat cable (at least they had the decency to label it
I just used the HDMI cable from the Blu-ray player. Airstream, welcome to 2010!
jondrew55 is offline   Reply With Quote
Old 07-24-2021, 11:54 AM   #12
Freedom
KCurtis's Avatar
2023 30' Classic
Dallas , TX
I had to remove the shelf that the DVD Player was installed in. This opened up the side of the trailer where all the cables where. My coax cable was deep down inside that side opening. Since we don't have any DVDs (got ride of all of them 10 years ago when we moved) I decided not to reinstall the shelf and remove the DVD player. We now have much more room inside that cabinet. I will reinstall it once we decide to sell our Airstream.
2023 30 Foot Classic
2022 Ram 3500 Dually
KCurtis is offline   Reply With Quote
Old 07-24-2021, 12:08 PM   #13
Oviedo , Florida
I bought a wireless HDMI extender to make it possible to broadcast the signal to an extra tv. I may have to pull this stuff out again to attach that.
Old 07-13-2024, 05:21 AM   #14
Virginia Beach , Virginia
From Wally to TV
I'm new to Dish but am waiting to receive my Playmaker and Wally in the mail. Thanks for letting me know where the Sat connector is for input to the Wally but what wire do I use to go from the Wally to the TV? Do I have to fish a new wire to the lounge TV (about 15ft) or do I have to split the DVR wire? Thanks in advance for the help.
petermday is offline   Reply With Quote
2020 Globetrotter 23FB Twin - Dometic RMD 8555 wont run on battery dianacr 2018 - Current Globetrotter 30 07-29-2022 06:20 AM
Water in Exterior Cable/Sat Connection "Box" UnklJoe Audio, Video & TV 2 12-13-2020 02:55 PM
2020 Globetrotter 23FB Twin Price FPT Dollars & Cents 1 08-27-2019 12:50 PM
Easter Egg? 2020 23’ Globetrotter FBT jeffmc306 2018 - Current Globetrotter 11 05-22-2019 03:22 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
