Old 05-30-2022, 10:33 AM   #1
2016 25' Flying Cloud
Waynesboro , Virginia
Backup camera extension antenna
Factory-installed Voyager backup camera on 2016 FC 25 stopped working this year. Extension antenna on front of trailer severely deteriorating (firmed up with some electrical tape last year). Wondering 1) how antenna can be removed (unscrew just above metal roof attachment?), and 2) if there is a replacement part. Can't seem to find it anywhere on the Internet.
jkhoover2 is offline   Reply With Quote
Old 05-30-2022, 05:56 PM   #2
AirstreamJim's Avatar
2009 34' Classic
Lake Worth Beach , Florida
That’s not an extension antenna for your backup camera, that’s an AM/FM radio antenna. The only extension antennas for the Voyager camera are an after-market purchase from the manufacturer, and the cable from the camera to the antenna runs along the outside of the trailer, on the roof. It’s a very easy DIY installation (although you could probably pay a dealer to do it for a lot of money if you really want to give away your money).
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 05-30-2022, 06:49 PM   #3
Escape Pod II
John Ware's Avatar
2018 22' Sport
2022 23' Flying Cloud
Orange , TEXAS
I replaced my am/fm antenna with one from AutoZone. It came with numerous adapters, which I didn't need. The rear view camera, if it's like mine, gets its power from the center marker lights. I've seen other posts where the camera can fill up with water. Good luck with it and I hope it's a simple fix..
JEWare
John Ware is offline   Reply With Quote
Old 05-31-2022, 05:22 AM   #4
Thanks for the clarification! Radio works fine so I guess I'll live with it a while longer. As for the backup camera I guess I have some more investigating to do. Thanks again.
Old 05-31-2022, 05:47 AM   #5
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Jkhoover2
Let me know if you find a replacement that works. I have the exact same issue and just did the electrical tape wrap. I would have expected it to last longer than 4-5 years especially when the trailer is kept under cover and out of the sun. Glad to know it’s just AM/FM as I thought it was voyager backup as well.
JDG is offline   Reply With Quote
Old 05-31-2022, 07:09 PM   #6
Adams Run , South Carolina
Maybe some large diameter heat shrink would help
Markhambryan is offline   Reply With Quote
Old 05-31-2022, 10:38 PM   #7
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
nut comes loose
The nut the holds the antenna connector in the camera comes loose then water runs down inside. How would I know this. I check that nut now every trip out and apply some silicone around it.
Life is a Highway is offline   Reply With Quote
Old 06-01-2022, 06:44 AM   #8
Mollysdad's Avatar
That's the radio antenna. Mine broke off too. I didn't want to replace the part sealed to the roof, so I took the screw out of the 'tilt' adjustment, bought another antenna on Amazon and I was done. I spent more time worrying about denting the roof than I spent changing the antenna.
Old 06-01-2022, 05:00 PM   #9
Thank you.......I found that antenna online and will follow your advice on replacement!
Old 06-15-2022, 09:58 AM   #10
2018 23' Flying Cloud
Voyager Backup Camera
We have the factory installed Voyager backup camera installed on our 2018 FC 23FB. The quality of the video on the monitor is bad. Is there a way to improve the resolution?
ahillring is offline   Reply With Quote
Old 06-22-2022, 09:58 PM   #11
Boise , Idaho
I found the reception on my 30ft trailer to be quite bad, the connection would go out if I made any turns, that's how borderline it was. Also the resolution wasn't good and I had a giant screen stuck in the middle of my windshield. I replaced it with an OEM Ford trailer camera which is hard wired and I can see a clear, consistent image right on my 12" truck infotainment screen.
mbronto is offline   Reply With Quote
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
