RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-23-2021, 03:16 PM   #1
2021 27' International
Lake Oswego , Oregon
Backup camera connection to Ram
I have a 2021 International 27 and a 2021 Ram Laramie 1500. The truck display has the ability to connect to other “aux” cameras, but I’m unable to get the signal from the Airstream camera. Airstream tells me the camera gets power from the 7-pin cable, but does not send the camera signal back to the tow vehicle on the cable; the camera sends a Bluetooth signal to the separate monitor that came with the trailer.
Has anyone figured out a way to see the trailer rear camera view on he truck screen?
Thanks!
Harlan27 is offline   Reply With Quote
Old 01-23-2021, 05:57 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Thanks!
I thought the Airstream provided camera utilized WiFi, not Bluetooth. Have you looked at the manual for your truck to see what the "aux" camera functionality supports? Does it require a hardwired connection, like the GMC/Chevy trucks with the invisible trailer option?
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 01-23-2021, 06:37 PM   #3
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
In the Ram, it isn't a wireless camera setup: it's looking for a camera to be plugged in on the back bumper.
-Leslie
LNBright is online now   Reply With Quote
Old 01-23-2021, 10:10 PM   #4
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
Also, be sure your headlights are turned on, not just auto, to get picture on the camera screen.
77 R GO C MH is offline   Reply With Quote
Old 01-24-2021, 10:16 AM   #5
Annapolis , Maryland
benefit of separate monitor
I considered this on my Ram, but ultimately used the monitor that came with the camera. happy I did, as we can use the RAM screen for navigation while using the trailer camera for rear view while driving.
I bought a Proclip mounting base and mountings for the monitor that fits perfectly on the dash above the navigation screen.
rhpeahl is offline   Reply With Quote
Old 01-24-2021, 11:04 AM   #6
Yes, I have tried with the lights in the “on” position. I do believe you’re correct about the truck looking for a hardwired connection from the 7-pin cable. I’m wondering if there’s some way / some device that would take the signal from the camera and incorporate that into the 7-pin cable.
Not sure if that technology exists.
Old 01-24-2021, 11:24 AM   #7
LNBright's Avatar
I don't think it's the 7-pin, that's for the lights, brakes, etc. Camera port will be in addition to that. At least on the GMs it is a separate port, I don't see how it can be other than a separate port. The 7-way has no way to bring in a camera signal.
Not being overly familiar w/ the Ram world, I'd suggest really comparing your truck's specifics (window sticker, packages that you have) against all the other options, to see if your truck does indeed have a towing camera package or not.
-Leslie
Old 01-24-2021, 08:31 PM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
RAM uses a 12 pin connector above the 7 Pin
You’ll find a lot of information about the RAM Aux camera on the truck forums. If properly equipped, you’ll find a 12 pin connector above the 7 pin in the bumper. Below is a photo of the 12 pin / 7 pin connector used for the RAM aux camera in the bumper.
The RAM aux camera kit isn’t cheap and comes with a wired harness that you’ll need to install. That one is for the HD truck but I imagine the 1500’s are similar. Talk to your local RAM dealer’s parts department for the details.
The Voyager camera included with your International will only work with the wireless monitor that came with it (not the RAM 12 pin). You might want to try the Voyager setup and see what you think.
I did what another poster suggested and got the optional Voyager 6” universal mount just above the radio. Works great!
ID:	387522   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-25-2021, 10:42 AM   #9
Thanks Jeff!
That’s a pretty definitive explanation; very helpful. Too bad it’s not plug and play as Ram might have you believe.
Old 01-28-2021, 07:43 AM   #10
2015 27' FB International
Miami , Florida
Hey Jeff thanks for sharing your setup. Can you provide some links for the products you mention particularly the voyager 6" universal mount? Thanks
pianolaw is offline   Reply With Quote
Old 01-29-2021, 11:42 PM   #11
jeffmc306's Avatar
McHenry , Illinois
Happy to provide the links
pianolaw, sure thing - happy to do so.
Voyager makes two universal mounts, 4" and 6". eTrailer sells both, here's the 6" one that I used.. The mounting base was about 1/4" too wide to fit in my RAM truck's top recess. I made my own from 1/8" thick 2" wide stock to use the two factory mounting screws rather than install Rivnuts. I repurposed an old mousepad to cover the plate.
Here's the RAM factory auxiliary camera kit (requires Auxiliary Camera Prep Package XFQ). That one is for a 2500-3500. 1500's are similar.
The nice thing about the Voyager is it's on all the time. I'm pretty sure the Factory Aux unit only works when in reverse or for a few seconds when going down the road. If your truck did not come with the XFQ prep package, you'll need to purchase and install that harness and get the computer updated.
Let me know if you're looking for anything else!
Jeff
ID:	387793   Click image for larger version
ID:	387795   Click image for larger version
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 01-31-2021, 11:40 AM   #12
Miami , Florida
Jeff
Thanks Jeff. I have a 2017 2500. Not sure my dash area is same as yours as there is just a narrow indentation on the top. But I'll check it out some more. I agree it's nice that the Voyager is always on as I use it as a rearview mirror - can't imagine towing without it as it really helps seeing what's behind me.
Chris
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 07:09 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 01:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 01:23 AM
