04-25-2025, 09:48 AM
2025 27' Globetrotter
Lillington
, NC
Airstream Rear Camera Mount
I don't know about you but the lightweight mount to hook to your windshield doesn't work. We have a 2025 27' Globetrotter and previously a 2024 25' International and had the same issues in both. Get ready to take off for a road trip and set the rear camera mount to the windshield then out of nowhere, and sometimes when you really need it, it falls off.
We were at the Region 3 Rally and one of the Vendors had what I thought was the ticket, a pump up suction mount that will not come off. It by itself wouldn't work for mounting the camera monitor, but with some engineering I've made a unit that WILL NOT come off. It will take all the bumps and bangs from the road and works great.
I'm trying to find out if others have the same issue or not or what the interest would be for this solution.
04-25-2025, 10:07 AM
2023 25' International
Long Island
, New York
Hi Tearle. Points for creativity! Personally, I dont like anything on the windshield. I just hold the thing, if we use it at all.
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
04-25-2025, 11:51 AM
2023 27' Globetrotter
Edmond
, Oklahoma
I altered an over the door towel rack so the monitor can hang from the rear view mirror.
I’ll try to post a photo later
04-25-2025, 01:54 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Just me...
I use Industrial Strength Velcro to attach our rear-view camera. No clamps or hole drilling needed. Run the power wire down the rain channel into the AS through the window and to the rear power port. (Cig lighter style)
04-25-2025, 02:03 PM
2019 23' Flying Cloud
Lacey
, WA
New camera and mount
I recently replaced my camera from Haloview and they did not supply a suction mount, I ordered that separately from Amazon. So far it has stayed attached for over a month and on some bumpy roads. Might work on the original monitor.
https://www.amazon.com/dp/B07Q4SJXF9...fed_asin_title
04-26-2025, 09:53 AM
2007 25' Classic
San Luis Obispo
Just buy a new GM truck and add the rear camera option. Then it will display on the main truck screen and you have nothing else attached to the windshield. All it takes is a bunch of money! Good luck!
04-26-2025, 12:46 PM
2019 25' Flying Cloud
Houston
I just installed a BT7. I have only done a couple of short tows, but I am liking the rearview mirror mount.
https://www.amazon.com/dp/B0D3HQMXL4...fed_asin_title
As for the OEM suction cup, yeah that didn't last long. Replaced it with a GoPro suction cup. Worked far better, but not perfect. Fell a couple of times over several years of use.
04-26-2025, 12:56 PM
2025 25' Trade Wind
Beaver Dam
, Wisconsin
There is the monitor, and then there is the actual camera.
My Trade Wind came with the camera permanently attached to the outside rear of the trailer. The Voyager monitor is heavy and pops the suction cup off the front windshield. Even when attached it blocks forward view and is illegal in many states.
I attached Velco straps to the back of the monitor and strap it to the rear view mirror. It blocks the mirror, but the mirror is not useful while towing a trailer anyway.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
04-26-2025, 09:38 PM
2018 27' Flying Cloud
INDIAN HARBOUR BEACH
Never had the problem. While it may be poor hygiene, lick the thumb, wipe on the suction surface, apply to window. I turn my rearview mirror vertical with the monitor mounted left of mirror. As stated above, can't use the rearview mirror while towing trailer. By the way, I have a Voyager monitor for sale.
05-07-2025, 09:29 AM
El Granada
We have a dashboard mount from Bulletpoint. We have a Ram 2500 and use the Rubigrid mount with arms for the Rear View camera monitor and tire pressure monitor
They have solutions for all makes of truck.
https://www.bulletpointmountingsolutions.com
05-07-2025, 09:37 AM
2024 27' Flying Cloud
Albuquerque
, New Mexico
I was wondering if anyone has experience with “bullet mounts” for the OEM monitor? Looks like it could be a solution.
05-07-2025, 09:42 AM
Albuquerque
, New Mexico
…and my post sped past Kamanrev’s in the ether!
05-07-2025, 09:57 AM
2023 23' Flying Cloud
Carroll
, Iowa
Not a fan of suction cups, in general and in life
FWIW... I found the "bean bag" tripod that goes with my HaloView monitor and it works real fine for us... it sits still and is easy to just grab the entire assembly together and stow in truck center console.
https://a.co/d/1yjI5di
'23 Flying Cloud 23FBT #1235 • '24 F150 XLT PowerBoost 7.2kw⚡️ • '10 Border Terrier 🐾
05-07-2025, 10:32 AM
El Granada
Quite frankly they are “bulletproof “. The build quality is exceptional and the design is well thought out. There is no chance that the attached monitor is going to fall off. Ever.
They are expensive. But on the other hand the cost was less than 0.1% of our new-ish trailer 😀
05-07-2025, 10:42 AM
Lake Oswego
, Oregon
These work great
I had the same problem. I tried everything. There is a reusable tough rubber band that is sold on Amazon called Nearockle cable tie. I’ve attached a screenshot. It attaches the screen perfectly to my rear view mirror. And never ever slips.
05-07-2025, 11:26 AM
Man of means by no means
2023 28' Flying Cloud
Midland
, Georgia
It is an issue
Same issue here. Also the ball ridges had smoothed to the point of being useless. I will say, Josh at ASA Electronics was incredibly helpful! They sent a replacement mount (complete) that arrived in two days! In the meantime I had already bought a Scosche MAGICMOUNT so I’m keeping the ASA one as a spare. The MAGICMOUNT has been flawless in use over a few trips now. And, being as it’s magnetic I can easily reach up to remove the screen. I did use the included plate & had to snip one edge so it would fit into the center position on the back of the screen.
The universe is expanding so that should thin out the traffic.
05-07-2025, 11:40 AM
Flagstaff
My 25' Globetrotter has a Reolink 4k POE 180 degree backup camera. You can view this camera via WiFi in the TV with the ReoLink apps.
Renders outstanding 180 degree views in back of the Airstream.
2026 LightShip AE.1<=>2025 Ford F-150 HEV PowerBoost 7.2kW ProPower
05-07-2025, 12:34 PM
D & L Gates
2024 25' Trade Wind
Pella
, Iowa
I will second this recommendation. I installed the Bulletpoint product in our '24 Silverado and it holds our rear view camera display and our Garmin RVCam 795. The mount fits perfectly, replacing the small tray above the display screen, and the attached devices are solid and steady. Really love this system.
2024 Trade Wind 25' FBT "Tickety-Boo"
2024 Chevrolet Silverado 1500 LTZ w/ 3.0 diesel & max towing
05-07-2025, 04:04 PM
Flagstaff
Got a PM about the mount used for this installation here it is.
05-07-2025, 05:02 PM
1997 28' Excella
, Kentucky
I suggest Ram Mounts. Take a look online at OC Mounts. They have a large selection of items to create most any mounting combination you want. I’ve been using their windshield suction mount. Very easy to mount and stays put.
