Old 06-25-2018, 03:58 PM   #1
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
Post 27FB wire path from battery box to dinette
I want to run some heavy leads from the battery box to the dinette area so I can put some Anderson Power Pole connectors to run my ham radio direct from the batteries without needing a power supply.
Know how to get the wire from the dinette to the area under the closet/shower. My trouble is how to get it from the shower area to battery box. With the length of run, I am thinking about running #2 cables so I won't have voltage drop. Not the easiest stuff so snake through small areas.
rdepas is offline   Reply With Quote
Old 06-25-2018, 04:40 PM   #2
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
You pretty much have to use some kind of wire chase like the picture below to run along the base of the wall to the nightstand.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 06-25-2018, 04:57 PM   #3
1979 28' Ambassador
2014 27' FB Classic
Hopefully there is a way to get into the belly pan area. I sure don't want to run a pair of #2 wires in a strip of wiremold in the bedroom area.
Old 06-29-2018, 02:48 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Ok, to run that way, you need to pull the covering off of the bottom of the belly pan. That likely also involves pulling the stabilizer jacks. That gives you access to the holes in the frame and the rings that the wire runs through. This assumes that it runs fully underneath on your trailer. On mine it runs in the wall above the belly pan once it gets past the dinette. That means a pull of the inside aluminum as well.
Most trailers ( but not all, check the manual ) run a piece of 6AWG from the battery up to the dinette area. It's good for at lest 50A. That also may be all it's wise to pull off of the stock batteries......
If you are using the standard West Mountain Radio power pole connectors, they will not accept anything larger than number 10 AWG. Why you ask? Well Anderson rates them for < 30A. The guys in Norwalk decided to re-rate them to 40A. No, that's not a guess, I used to eat lunch with them on a regular basis.
The easy answer is to just tag into the existing cable.
Old 03-07-2021, 04:22 PM   #5
2013 27' Flying Cloud
Calgary , Alberta
Hi Frank,
I am about the run wire the same way but do not see any screwed at the front of the nightstand holding it down. Do you remember how you got it off to run the wire?
Peter
Peter C is offline   Reply With Quote
Old 03-08-2021, 06:09 AM   #6
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
I ran mine in seal tight under the trailer with entry points at the front and just past the water heater. I ran (2) #2 plus some control wiring from the roof through the pantry to the power entry area at the front of the trailer. Vinnie of Vinnie's airstream has found a way to route cleanly in holes in the outriggers inside of the banana wrap which is a much cleaner run. - Brad
SuperTrouper is offline   Reply With Quote
White wire in battery box? mweberg Electrical - Systems, Generators, Batteries & Solar 14 07-02-2018 10:41 PM
Adding new wire from Battery box Rust Batteries, Univolts, Converters & Inverters 2 05-17-2015 08:57 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Battery Box wire?? OakHill Electrical - Systems, Generators, Batteries & Solar 9 12-11-2003 09:50 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
