Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Full-Timing
Old 07-14-2010, 11:00 PM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Flag Pole Holder
Does anyone know where I can buy a 2 or 3 flag pole holder that would attach to the front of my Airstream?
Bing-Bing is offline   Reply With Quote
Old 07-14-2010, 11:10 PM   #2
_
this whole thread may help, but
start paying attention at post #52 here...
http://www.airforums.com/forums/f44/...ies-43117.html
cheers
2air'
Old 07-16-2010, 08:54 AM   #3
Bing-Bing's Avatar
1994 34' Excella
Thanks 2air' now I remember reading all about this two years ago...the memories slipping.....
Old 07-16-2010, 09:02 AM   #4
tksbaskets's Avatar
2007 25' Safari FB SE
Dexer , Michigan
We got ours from pole ease in Jackson MI. DH did have to make a couple of modifications but was 'easy to do'. The gang also assisted when he adjusted the poles so the American Flag is higher than the other two.
POLE EASE
6501 Wolf Lake Rd.
Jackson, MI 49201
Phone: 517-536-8022
tksbaskets is offline   Reply With Quote
Old 07-17-2010, 11:16 AM   #5
Bing-Bing's Avatar
1994 34' Excella
Thank you, tksbaskets I'll give them a call...
Old 07-17-2010, 12:43 PM   #6
I got my 5-flag-pole holder from Rob Baker of VAP fame. He also has 3-pole versions. You can PM him at robandzoe here on the Forums.
Old 07-17-2010, 12:56 PM   #7
_
like 'baskets and 1000s of other streamers...
my gear ALSO came from pole eaze...
they've been advertising these holders and poles for decades in the bb...
and have sold the stuff at the wb' headquarters for a long long time.
rumor is that the wb'hq no longer carries this stuff,
i haven't confirmed this but the parts from pole eaze are FIRST RATE,
so checking with THEIR jackson michigan location is a good first choice.
cheers
2air'
Old 07-17-2010, 01:33 PM   #8
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
3 and 5 poles before polishing
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 07-17-2010, 07:39 PM   #9
tksbaskets's Avatar
Dexer , Michigan
The picture that robandzoe shared is very similar to what we have. I don't know if he also sells the poles. It was nice to have one-stop-shopping.
Old 07-17-2010, 07:45 PM   #10
2000 34' Limited S/O
Greensboro , North Carolina
Got my 3 pole holder from Rob Baker on the forums as well. Great qualtiy.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 07-18-2010, 09:56 PM   #11
Bing-Bing's Avatar
1994 34' Excella
Thank you all.... I appreciate you taking the time to enlighten me.
Old 07-18-2010, 11:10 PM   #12
Rob,
Is this a picture of patina finish? Can you give us a picture of holders after polishing. Thanks.
pattonsr is offline   Reply With Quote
Old 07-19-2010, 06:26 AM   #13
My poles are just extendable painters' poles from Lowes (upon Rob's suggestion). They go from 6' to 12', and are an inch diameter at the base, which is the correct dimension for the holders.
If you went that route, you'd have to remove the rubber handle at the base, and I drilled some holes at the top for my carabiners to go through, and hold the flags in place.
Old 07-19-2010, 09:57 AM   #14
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I used the painter's poles but put the small end at the bottom and attached the top grommet of the flag to the plastic handle.
Putting the small end down has the added benefit of keeping rainwater from running down the pole and getting in and corroding the poles' locking mechanism.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 07-23-2010, 09:23 PM   #15
Here is a link to a collapsible pole available with Internet access and a credit card. Scroll down to Collapsible Flagpoles To Go. Warning, they are not cheap, but they are really nice, and very easy to store.
This was on a previous post and I purchased mine from this site. It is very nice, easy to store and I'm happy with it.
WBCCI #4358
Old 10-28-2010, 12:57 AM   #16
2010 28' International
ROCKWALL , Texas
I see they also have some 3x5 flags. How did you attach the flags to the pole? Also, those flags are tapered...If you have the 12' or 15' does it "hold up" and not bend in higher winds?
IDAG95 is offline   Reply With Quote
Old 10-28-2010, 06:43 PM   #17
They came with the eyelets to attach the flag. I bought the 15' and you can adjust the height. I run mine up enough to put the bottom of the flag just above the top of my center cap. It has held up in the winds. The only problem is that the diameter is not quite an inch and my holder is an inch so I have had difficulty with it turning in the wind.
WBCCI #4358
Old 10-28-2010, 07:32 PM   #18
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
How about drilling a small hole in the holder that lines up with the center of your poles and inserting a nice SS pin of some sort there to keep them from twisting ?
T & K
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 10-28-2010, 11:17 PM   #19
ROCKWALL , Texas
Thanks!
Old 10-29-2010, 01:25 PM   #20
Thanks thats a great idea! I'm a numbers guy so I like hanging out with you smart technical types.
WBCCI #4358
Flag pole holder grnthumbguy Exterior Restoration Forum 3 10-21-2017 11:23 AM
Flag Pole Holder Installation DEITZ645 Exterior Restoration Forum 6 07-27-2010 08:35 AM
I Want a 5 Pole Flag Holder/Bracket myboyburt WBCCI Forum 45 12-28-2008 06:45 PM
pole-ease flag holder question Chuck General Repair Forum 9 10-07-2008 12:20 AM
Flag pole bracket/holder? Kistler Our Community 7 11-25-2003 10:29 AM
