Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Full-Timing
Old 02-19-2020, 11:50 AM   #21
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
a fridge or air conditioner is a dehumidifier, that is how they work
waninae39 is offline   Reply With Quote
Old 02-20-2020, 01:14 PM   #22
Jasper Ash's Avatar
West Palm Beach , Florida
Great information here! SewStream, thanks for the post about the dehumidifier that can help dry laundry. We keep a couple of microfiber cloths around to wipe down anything wet, including surfaces, the aluminum skins, the shower, etc. in an effort to combat moisture. But then the towels sit around wet. We can’t really put them outside to dry on most nights because the humidity outdoors will keep the towels wet all night long. Wet bath towels and microfiber cloths laying around are certainly adding to our humidity issue. I’m tempted to buy a small clothing dryer.
We full time in a 27FB in South East Florida. Humidity is always an issue here. Even during our cool months we find ourselves running one or two of the A/Cs just to control the humidity.
RuthTheBambi... it sounds like you’re doing just about everything one can do to control the humidity. The bit about the mattress and underlying plywood is something I need to look into. Our humidity is never below 50% either.
I hope you find a solution, good luck!
2020 Flying Cloud 27FB w/ Rear Hatch
2017 Toyota Tundra SR5 Double Cab 5.7 FFV
Jasper Ash is offline   Reply With Quote
Old 10-27-2020, 04:33 PM   #23
2012 31' Classic
1996 34' Cutter Bus
Dallas , Texas
Really great information. Having a dehumidifier at home is a great thing. You know I grew with my grandmother and we were living in a small old house. The air in the house was always very wet. I don't want to speak about the basement, humidity was always present there. I think that now I have problems with my lungs because of that. I cannot breathe normally when I'm in a wet area. That is why I found a lot of information about the dehumidifiers from the Aero State and bought the best one. To be honest I didn't know that I have to take into consideration so many thing buying a dehumidifier. But it works and helps me a lot!
Joseph1986 is offline   Reply With Quote
Old 09-18-2021, 06:49 AM   #24
True. If your AC is working properly, it will pull humidity out of the air. That is how it cools.
Too bad Airstream AC’s don’t have a dedicated dehumidifier mode like the Mitsubishi Mini Splits do. I have the Mini Split in my shop (SE Texas) and only run it on dehumidifier mode all summer and most of the winter.
It keeps the humidity below 50% and the temp below 70 degrees, even on hot humid Texas days.
Anxiously awaiting delivery of my GT27FB scheduled for the end of October. It will have two AC units.
Woolecox is offline   Reply With Quote
Old 09-18-2021, 07:05 AM   #25
1966 22' Safari
Fredericksburg , Texas
The mini split in our 55 has a dehumidifier setting that really helps keep things dry once we get to set point.
Bubba L is online now   Reply With Quote
Old 09-18-2021, 07:49 AM   #26
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Living in the south where the humidity is rather high most days, I use these products regularly.
Damp-Rid (Sam’s or Walmart)
ProBreeze
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 09-18-2021, 08:35 AM   #27
2021 30' Globetrotter
Oviedo , Florida
An air conditioner is a cooling unit that removes humidity as a byproduct of cooling the inside air. It transfers the heat to outdoor coils. A compressor dehumidifier has all the components indoors and as a result actually increases the indoor temperature because it must do mechanical work to move the refrigerant to remove the humidity. I don’t see how a fridge fits in here at all except if it’s humid enough you get condensation on the door.
jondrew55 is offline   Reply With Quote
Old 09-22-2021, 06:24 PM   #28
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Ruth, for the bed we have the following that can be purchased from the Airstream Supply Store. https://airstreamsupplycompany.com/p...isture-barrier .
As for the inside of your rig, that has been pretty well answered. Good Luck.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
cold weather, condensation, full-timing, fulltiming, humidity, moisture, mold
Condensation / Humidity Woes! Zigidachs Windows & Screens 9 01-28-2013 04:44 PM
Controlling Black Tank odor thecatsandi Waste Systems, Tanks & Totes 36 05-03-2012 06:49 AM
Controlling humidity Catman6 Full-Timing 23 03-31-2010 02:55 PM
Moisture / condensation treatment? jking Classic Motorhomes 3 11-23-2007 12:37 PM
Controlling Humidity chaimemet Dehumidifiers & Ozone Generators 2 06-17-2007 06:07 AM
