Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 03-26-2017, 05:51 PM   #1
israndy's Avatar
2005 39' Skydeck
Alameda , California
Water leak stains on wall fabric
When I first saw the Skydeck at the dealer I asked about removing the stains on the wall fabric, the dealer said he used a product that NASA uses in SPACE and he got no where in removing the stains.
I was not sure what caused the stains either, but I have since found its water getting in the extruded top rounded corner piece where the ceiling meets the walls. Somewhere water is getting in and filling this 40 foot piece of metal, and then the ceiling trim is screwed into this and the water leaks around the screw and gets the fabric stained with rust.
I had tried a wet vac and decided I cannot fix this, and would start looking for replacement fabric. I have NOT found new fabric of this pattern but I did find a product called InstaGone. Decided to give it a try. I was surprised with the results, not perfect but may allow me to keep my wall fabric:
I know OxiClean has been recommended and I will probably use that to try to scrub the walls as they are not uniformly white now.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight
And all electric: March 2018 Tesla Model ☰, a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles
israndy is offline   Reply With Quote
Old 03-26-2017, 06:04 PM   #2
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Some times lemon juice will remove rust stains. It can change the iron oxide chemically to a clear state which can be flushed with water.
Dennis
dennis3751 is offline   Reply With Quote
Old 03-26-2017, 06:06 PM   #3
Lily&Me's Avatar
Normal , Illinois
Wow...that looks pretty good!
I am a big fan of OxyClean.
Maggie
Old 03-28-2017, 12:14 PM   #4
israndy's Avatar
2005 39' Skydeck
To be clear, the results posted above are using InstaGone, as I linked to above. I have yet to try using OxyClean nor Lemon Juice. I had used my carpet shampoo upholstery attachment and got zero impact, so this is quite the win. The woodwork got a little white from the overspray, but when I wiped with a wet cloth days later it looked perfect.
-Randy
Old 03-29-2017, 12:56 PM   #5
Fuquay Varina , North Carolina
Febreeze (sp?) also does a pretty good job removing water stains from fabric.
ggimlick is offline   Reply With Quote
Water stained wall fabric replacement israndy Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 08-13-2015 09:39 AM
Stains on curtains and grease stains wallpaper near upper cookstove oxblood Upholstery, Blinds, Walls & Interior Finishes 0 04-07-2015 06:52 PM
Drape Stains..water? Sav'h Steve Upholstery, Blinds, Walls & Interior Finishes 11 10-15-2009 08:15 PM
interior wall stains - leaking or ???? jm2 General Interior Topics 4 06-07-2009 07:03 PM
Interior wall stains bensonortho 1997 - 2004 Bambi 2 12-20-2004 11:35 AM
