07-04-2017, 11:57 AM
#21
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
When I first looked at this I thought the cylinder in the photo was an LPG tank, but see now that it is the engine exhaust muffler.
I like the larger feet on your jacks. I have a smaller disc on the CLIPPER. I use rubber pads when I am on asphalt or soft ground.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
07-13-2017, 08:52 PM
#22
1998 36' Land Yacht Widebody
Shepherdstown
, West Virginia
What a beautiful coach!! I am jealous....love my diesel Landyacht but full-timing with it shows the limits. No slides but I do have washer dryer....would rather have a larger freezer but the Dometic units will not fit in my basement storage. Would have to delete the washer dryer and reuse that space.
Hope you make it to the Rally in Michigan later this month. Would love to see it up close! This is giving me the bug to go shopping again
09-21-2017, 06:19 PM
#23
2002 36' Land Yacht XC Diesel 300 hp w/2slides
LIVINGSTON
, TX
Bob, I'm told there is a company in Florida that specializes in replacing motorhome fogged windows and they have a good reputation. Unfortunately, I can't remember the name, but perhaps if you Google search "motorhome replacement windows florida" you might get a hit.
Herb Baldwin
2002 Airstream Land Yacht 36 DP MH'
2006 Saturn Vue
herbsells@gmail.com
08-10-2020, 12:25 PM
#25
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
08-14-2020, 12:15 PM
#26
north blenheim
, New York
08-30-2020, 11:43 PM
#27
north blenheim
, New York
09-01-2020, 09:02 AM
#28
2005 39' Skydeck
Alameda
Wow! Send Pics! I have that exact issue. I tried to remove the dining room window and clean it with just chemicals. Ended up putting yarn on a straightened coat hanger to scrub the glass. Sadly it left a pattern, though it is no longer fogged. I think I will just get the Dave Root kit and take my windows apart, and replace any glass I break. Drivers window looks the hardest.
09-02-2020, 03:50 PM
#29
north blenheim
, New York
09-06-2020, 04:46 PM
#30
north blenheim
, New York
Another great trip to Cooperstown ! We’re definitely going to take the 396XL to the Tetons and Idaho next summer. I really screwed up my left shoulder last week so I have not been able to do my usual work load, been popping Tylenol’s like M&Ms the last few days and getting a lot of sleep. Maybe I’m just starting to fall apart, I turned 60 a couple of weeks ago. I sit here looking at the 396XL and the list of work keeps getting longer. The electric step motor burnt out Friday before we left, at least it’s in the up position. I got the leveling system key pad reset but still have to deal with the wiring problem in the rear near the pump, I believe it’s a ground problem. The front side windows (6) should be here in a couple of weeks and that will take care of the fogged window issue. I broke the red handle off the escape window in the bedroom testing it. I’m skinny so I can fit out the slider if I have to. I need to figure out how the solar system works. The city water connection regulator leaks behind the panel and I want to ad a water spigot in that cabinet for a garden hose so that’s on the list for the winter. Still have the overheating issue after the first ten miles of driving.....I’m going to replace the thermostat (s) when I get back. Regards, Bob
10-20-2020, 08:55 AM
#31
north blenheim
, New York
I just finished cleaning the engine compartment. Getting ready to change the thermostat. I now have the correct windows coming for the left side. I ordered the incorrect windows for the left side cause I was to lazy to check their measurements. The first picture will show the correct measurements, the second picture will show the incorrect measurements. I now have a set of incorrect left side windows so if anyone needs them at a great price let me know. They are solid 7/16” laminated glass windows and u can ship them from my loading dock, Regards, Bob Attachment 1
10-20-2020, 08:56 AM
#32
north blenheim
, New York
11-07-2020, 11:48 PM
#33
north blenheim
, New York
Getting it all jacked up and ready for brake service and new tires, found the sway bar links need to be replaced, also noticed that the front end only has one leveler adjuster....on the left side. Gonna order a set of centramatics as well. Regards, Bob
11-08-2020, 11:38 AM
#34
north blenheim
, New York
11-16-2020, 03:44 PM
#35
north blenheim
, New York
I now have all of the 7/16” laminated glass in my shop, going to start pulling the skylights off next weekend, still waiting for the new tires, all brake shoes, drums, and Centramatics ordered. Progress and still have a list of stuff on the 370LE to do...,,,going to be a busy winter, Regards, Bob Attachment 1Attachment 1Attachment 1
11-23-2020, 08:57 AM
#36
north blenheim
, New York
11-24-2020, 09:42 AM
#37
2005 39' Skydeck
Alameda
Wow! Not having a 16 person patio on the roof sure leaves a lot of space for solar
12-08-2020, 01:06 PM
#38
north blenheim
, New York
12-10-2020, 09:06 AM
#39
north blenheim
, New York
12-11-2020, 10:18 AM
#40
2005 39' Skydeck
Alameda
What did you may for the big batteries? Did you find a deal?
