Old 12-24-2019, 12:31 PM   #1
Fayetteville , AR
Slide out Cutter 35 DP
I am a newbie coming into RVing. I am trying to avoid having a slider out but am now looking at a 1998 Clipper. My question is will the kitchen function properly if the slider is not extended? My thought here is that if not used then it shouldn't become a problem.
Thanks in advance for your opinions.
Rick
Big_smile_2u is offline   Reply With Quote
Old 12-24-2019, 09:07 PM   #2
2000 36' Land Yacht XC Diesel
Conroe , Texas
I have a 2000 35XC and I can use all of the kit hen items with the slide in.
Lford is offline   Reply With Quote
Old 12-25-2019, 03:11 AM   #3
Fayetteville , AR
Thanks for responding, I appreciate it. Quick question... would you buy another Airstream?
Rick MERRY CHRISTMAS
Old 12-25-2019, 08:29 AM   #4
Conroe , Texas
Yes I would
Old 12-25-2019, 10:16 AM   #5
Fayetteville , AR
Thanks again.
Old 12-25-2019, 10:56 AM   #6
High Desert Cat
2018 33' Classic
2021 19' Caravel
1999 35' Cutter Diesel Bus w/slide
Santa Fe , New Mexico
I have a ‘99 Cutter. Currently restoring it. The slide-out doesn’t affect anything, except swiftly moving about.
Enjoy!
I also have have a 2018 Classic 33.
akmoores is offline   Reply With Quote
Old 12-25-2019, 01:02 PM   #7
palm beach gardens , Florida
Sure wish they would put slides in again starting with the 25.
m rafferty is offline   Reply With Quote
Old 12-26-2019, 06:46 AM   #8
High Desert Cat
2018 33' Classic
2021 19' Caravel
I lived in the Denver area for nearly 20 years. My first Airstream was a 28’ Safari with a slide out. It was a wonderful thing - more room. I became aware of a company which would repair/ remodel/restore RV’s, Campers, buses, etc. they had a number of Airstream customers. They were told, by Airstream, in essence, ‘don’t put slide outs on AS any more’ because of the potential failures. Huh? I loved mine!
Old 12-27-2019, 12:07 AM   #9
Fayetteville , AR
Thanks for the input!
Old 01-06-2020, 09:17 AM   #10
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
The kitchen - and the rest of it is fully functional on our 35'Cutter regardless of whether the slide is in or out
Tony Lee is offline   Reply With Quote
Old 10-06-2020, 10:01 AM   #11
High Desert Cat
2018 33' Classic
2021 19' Caravel
Anyone in the process of restoring a Cutter?
If Kermit the Frog said it, I believe it's true!
Old 10-07-2020, 01:07 AM   #12
I just work on keeping it from falling apart as fast at it would like to.
Must admit that our trip up the Dempster Highway and on to Tuktoyaktuk didn't improve it much - especially the thick layer of calcium chloride on everything below floor level.
https://photos.app.goo.gl/9d4fxDmK4wyBJec2A
Window gasket creep and water damage under front and rear cap junctions and the odd bit of delamination make it truly unique, but even then it gets lots of nice comments about the appearance.
Old 02-09-2021, 07:29 AM   #13
1998 35' Cutter Diesel Bus w/slide
Albuquerque , New Mexico
We just purchased a 1998 Cutter deisel pusher with slide out. Have started doing minor repairs. What should I be watching for?
Jim McCabe is offline   Reply With Quote
Old 02-09-2021, 10:34 PM   #14
High Desert Cat
2018 33' Classic
2021 19' Caravel
Just watch out for everything. If a dog’s life is 7 to 1 of a humans life, I think a Cutter is 15 to 1. I think is Cutter is well build, but the ‘gadgets’ are questionable. The motor, drive train and transmission are most important. Keep reviewing the forums for other’s experiences. Good Luck
Old 02-10-2021, 03:43 AM   #15
Long Island , New York
Great that you are all are keeping these MH running.
Photos for the peanut gallery would always be appreciated!
Travel safe . . . and . . .
Let the music lift you up . . .
Old 02-11-2021, 12:39 AM   #16
See the attachment.
I can guarantee you will never see another Airstream Cutter at this place.
Never!
Photo caption is
"The obligatory "We Woz Here" photo. Worth taking because this is the only place in North America where you can drive yourself to the Arctic Ocean"
I can tell you that driving on 30km of freshly laid and watered calcium chloride does even worse things than 800km of fairly rough/muddy/slippery gravel rd
Old 02-11-2021, 07:01 AM   #17
Magnet18's Avatar
Churubusco , Indiana
Originally Posted by Tony Lee View Post
See the attachment.
Never!
Photo caption is
I think I would have probably abandoned it there and call a helicopter rather than drive 500 miles of gravel back
Impressive pic
Magnet18 is offline   Reply With Quote
Old 02-12-2021, 10:03 PM   #18
Impressive pic
Nearly had to. That calcium chloride mud broke some wiring hanging down under the engine that I thought was just wiring associated with towing - which we have never had - so I cut a few off short and tidied it all up.
Few days later we went for a drive and found I only had reverse gear.
Was a bit of a worry until I figured out what had happened and reconnected one critical wire.
Old 04-08-2021, 12:43 PM   #19
Rockledge , Florida
Anybody know who makes the slidout mechanical system on the Cutters
lewengel is offline   Reply With Quote
Old 04-08-2021, 02:23 PM   #20
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I don't know which organization(s) built your slide out mechanisms but industry consolidation has resulted in Lippert becoming the source for most of the mechanical and electrical parts to repair slide outs. Most of the gaskets are found elsewhere.
https://store.lci1.com/shop-by-depar...out-parts.html
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Road side slide out slide out 02 x365Xl Land Yacht Dewey1966 Land Yacht/Legacy Motorhomes 0 08-21-2018 11:33 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 09-07-2011 01:40 PM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-22-2011 06:30 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-11-2011 10:10 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-01-2011 09:40 AM
