11-07-2020, 05:43 PM
2005 39' Skydeck
glen gardner
, NJ
Skydeck fog lights help replacement or upgrade!
Hi all- Finally got my skydeck a few weeks ago and my fog lights are broken/cracked. I have the parts book and found the fog light but can’t find them anywhere
511879 fog light clear round
Or any ideas. The back of the fog lights have 1 bolt that hold it in place.
Thanks in advance
11-11-2020, 01:54 PM
2005 39' Skydeck
glen gardner
, NJ
Thanks in advance
Anyone have any ideas? Someone must have done something different? Or am I posting this in the wrong place? Any help. Thanks
11-11-2020, 03:11 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Welcome to AirForums & congratulations on your new-to-you Skydeck! I think you may not have gotten (m)any responses is there aren't a lot of Skydecks out there. Cool rig though! Hope you find what your looking for ~
Shari
11-11-2020, 03:21 PM
2018 25' International
Slidell
, Louisiana
If you're looking to keep the original look, it might be hard, but I remember back then and these are very similar to the common aftermarket ones popular at the time. Looking at Amazon, I see some options with the one bolt attachment. Some are even a bit similar to what you have. https://www.amazon.com/Automotive-Dr...?node=15736441
11-12-2020, 01:48 AM
2005 39' Skydeck
glen gardner
, NJ
Thanks-I just don’t want to keep putting holes in fog light area. Was looking for same fog light and I would upgrade the light to led. The setup of the fog light is odd with only 1 bolt going thru to hold it in place. Checked Napa autozone Walmart But might have to cave and put new holes in there. Thanks!
11-12-2020, 01:55 AM
2005 39' Skydeck
glen gardner
, NJ
Shari
Thanks. Yes I agree. :/. Was thinking someone would have a place or idea for a 1 bolt fog light as it gets recessed into a hole. Kinda a weird design. But that’s airstream for ya I guess. Hahaha. Surprised that there isn’t a cross reference for part numbers either. It’s not that old. Haha. Nice airstream that u have as well! Enjoy
11-12-2020, 02:05 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Can't you just fit the existing bracket to any modern spotlight with the same diameter, ie modified the light, not the motorhome?
11-13-2020, 04:21 AM
2005 39' Skydeck
glen gardner
, NJ
Well the lense is gone on the original fog light so the bulb/led will be out in elements. When I get to rv tomorrow I will take a picture of bumper where bolt goes into. Might just have to go 3” instead of 4” and then any fog lifer would fit... this fog has 1 bolt and when pulled tight it locks into place. I have fog lights and off-road lights but they mount on bottom and don’t go angle enough for a horizontal insert. All are sorta vertical insert.... hope that makes sense. I might weld something to make it work. Not into drilling a new hole and then weaken that area...
11-14-2020, 04:26 PM
2005 39' Skydeck
glen gardner
, NJ
Fog light replacement
So as you can tell the hole is in the back. It at the bottom and want to use the same hole.... thanks
01-18-2021, 06:37 PM
2005 39' Skydeck
glen gardner
, NJ
Another thing done
Got fog lights added. Needed a extra long m stainless steel bolt. Works great. :-)
