Old 07-23-2020, 04:13 PM   #1
1998 34' Cutter Bus (Ford)
Nanaimo , British Columbia
HVAC Control Cable
The heater control cable on my 1998 34' Cutter bent. Does anyone know replacement part source or number? Unit is Ford based.
Island Karma is offline   Reply With Quote
Old 07-25-2020, 09:46 AM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
ACME AC parts has what you need, suggest that you eventually switch over to a DC controlled heater control valve. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-25-2020, 09:11 PM   #3
By DC, do you mean a 12 volt system like on modern cars with temperature setting and "Auto" function? Is this difficult to do? The existing unit has a cable control to balance heat/AC and several push buttons that operate air or vacuum lines to floor/vent/defrost etc..
Old 07-27-2020, 03:43 PM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 59
Your dash controls for the heater/ac are a Chrysler product from the 70's. Parts are found at the wrecking lot, or you may try your Chrysler/Dodge dealer. Dodge vans and trucks. The autos of that period used a modified version of same system.
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 07-27-2020, 03:54 PM   #5
masseyfarm's Avatar
Images: 59
https://www.airforums.com/forums/f31...tml#post981579
Old 07-27-2020, 05:09 PM   #6
Excellent! I tried the Ford dealer and they were no help at all.
Cut-Off Switch for House Battery: Install on the Negative Cable or Positive Cable? Searching Batteries, Univolts, Converters & Inverters 27 04-18-2020 06:08 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 02:13 PM
Generator--HVAC Question Tideair Generators & Solar Power 10 03-14-2012 09:24 PM
Airstream - Free Standing HVAC anglev Winter Living 8 12-04-2011 07:20 AM
