Another possibility...
Your tank might not be cracked - there are other problems like a vent tube which is slipped from its mounting point on the tank or cracked which could be the problem, or a rubber mounting collar for something which wasn't installed correctly.
Great point.
Another possibility is the toilet flange, which is screwed to the floor same as in your home, has cracked down below the floor but above the tank. The flange itself is likely screwed into the tank.
Because the flange is fixed at both ends, age and pounding down the road can cause the flange to crack, allowing seepage through the crack and onto the outside of the tank, producing the odors.
Might be worth a look before you tear out the tank.
Good luck. John
______
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Jerry Garcia
