Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-31-2020, 11:49 AM   #1
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence , Kansas
396XL Leaning Toward the Curb Side
The right rear of my 2006 Airstream 396XL does not settle down as fast as the other 3 corners of the motorhome. After about 2/3 days it does settle down. Can anyone tell me what is wrong?
ttbikes is offline   Reply With Quote
Old 03-31-2020, 12:01 PM   #2
Mollysdad's Avatar
There are ride height adjusters built into the air bag system.
They are easily adjustable IF you can get to them. Motorhomes don't have easy access to the chassis. My Spartan chassis had a switch that dumped the air or stopped dumping the air.
Is yours level while the engine is running? Or after you dump the airbags? In between? If it's just settling after stopping, then perhaps you have a slow leak in that side air line.
When I parked I always just dumped the air and let it settle on the frame rubber stops.
Old 03-31-2020, 02:03 PM   #3
1964 24' Tradewind
Lawrence , Kansas
Well to be honest I am new to all of this. I not sure what you all mean by dumping the air bags. I engaged the air brakes. I did not put down the leveling jacks. It appears to just be the left rear and it does go down over time but slowly. If you stop and use the leveling system it levels but the right rear may be a little slow reaching level. I pretty sure it is level with the engine running.
Old 10-22-2020, 09:50 AM   #4
1964 24' Tradewind
Lawrence , Kansas
So I think I have got to the bottom of my problem. I took it to Freightliner and they found a leak in air line fitting of the air ride system at the diver side rear. Now I have the problem of finding the part. It is not a Freightliner part. It is not listed in the Airstream parts book. I contracted Colaw Salvage and they don't have the part. I have included a picture. Any ideas where I can find this part?
Old 10-22-2020, 10:52 AM   #5
1964 24' Tradewind
Lawrence , Kansas
An additional bit of information. Repair guy thinks it is a check valve. He can see a spring in side.
Old 10-26-2020, 09:55 AM   #6
1964 24' Tradewind
Lawrence , Kansas
Just an update for you all. I found the part a Days Diesel in Red Oak Alabama. Freightliner had told me it was not a Freightliner part but it was. Turns out it was part of a kit. Also, comes with a new height valve.
2018 Basecamp leaning to the side nelulay General Repair Forum 36 12-04-2018 06:34 AM
Steps fought the curb and the curb won badkat Airstream Lifestyle 13 06-22-2013 03:03 PM
Leaning toward Yamaha 1000 ESCAPE POD Generators & Solar Power 7 03-21-2013 11:08 AM
Leaning Tower of Airstream hoppingviola Repairing/Replacing Floor &/or Frame 3 10-05-2011 12:11 PM
Why am I leaning? onwisconsin General Repair Forum 8 07-09-2011 04:37 PM
