Winterizing questions
We just took ownership on a 2000 Land Yacht and winter is fast come upon us.
While I have winterize my trailers for over 40 years the Motor Home has some new issues and I am asking for input.
How to winterize the washing machine? it looks like a problem to get to the shut off valves and loosen the hoses to drain the water back. Then the machine pump is another question.
It looks like they did not use 1/4 turn valves on the water heater bypass as the valve will turn 2 1/2 turn like a normal S&W valve. Is that correct?
Is the washing machine screwed to the floor and if so where are the screws?
2004 Excursion 4x4
