Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 07-29-2019, 08:43 AM   #1
1995 36' Land Yacht
Gretna , NE
Water tank drain
I was wondering if anyone knows how to drain the fresh water tank on a 1995 airstream landyacht 36ft mh
Rweak is offline   Reply With Quote
Old 07-29-2019, 09:00 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Not sure if it's relevant but on my 1992 LY 36 footer the valves are under the bed. I have to remove the street side drawer to access the valves. There's three valves. You open all three and open all the facets to drain.
92landyacht is offline   Reply With Quote
Old 08-02-2019, 11:54 AM   #3
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
Is yours a diesel? On mine there is a valve in the water compartment that drains your tank and water lines. If your goal is to get it totally empty, suggest opening the valve, use your pump and open sink faucets. If you have levels, raise the right-side so its tilted and let it sit that way for several hours.
The drain valve is in the front left side of the water compartment and has a tube exposed on bottom. This is the low point drain and also an entry point for bugs so make sure its sealed if not already.
Mike1997 is offline   Reply With Quote
Old 08-02-2019, 11:57 AM   #4
Sag Harbor , New York
Do you have the owner's manual? If not, one can probably be located on the Airstream site, so please advise for further info.
Old 08-03-2019, 05:44 AM   #5
1995 36' Land Yacht
Gretna , NE
It's a gas mh, I have the manual book it was kind of vague , I have tried that valve before and heard water spraying out . Now I know to look for a hose underneath.
Old 08-03-2019, 05:46 AM   #6
1995 36' Land Yacht
Gretna , NE
Thank you all for the posts
White water tank drain ramoore53 Fresh Water Systems 5 02-19-2024 04:08 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
