Old 04-22-2018, 04:14 PM   #1
Mike1997's Avatar
1998 36' Land Yacht Widebody
Reidsville , Georgia
Images: 14
TV Upgrade Project
My Airstream came with a large heavy 19" tube TV and a VHS player mounted in the center cabinet at the front. I chose to replace it with a 24" flatscreen with built in DVD player where disc enter from the right side of the TV.
I removed the old TV and mounted a standard computer monitor articulating arm with a clamp base. Around the outer edges (not visible) is Velcro strips that hold it in place while traveling. Usually add a bungie cord for support when traveling on rough roads like the PA Turnpike!!
For greater sound effects, I added a 22" Bose center speaker/amp that sits directly under the TV. Excellent sound in a small package
Here are before/during/after pictures of the install. If anyone has questions, I have more detail photos that can be shared.
ID:	309286   Click image for larger version
ID:	309288   Click image for larger version
Mike1997 is offline   Reply With Quote
Old 08-27-2018, 07:53 PM   #2
2000 36' Land Yacht XC Diesel
Conroe , Texas
Can you email me more photos ?
I havd have a LY 35xc diesel pusher 2000 model and i am looking at that same upgrade. My coach interior is being upgraded, new carpet, upholstery, and shades. How high does the TV go?
Wished it was mounted uptop.
Lford is offline   Reply With Quote
Old 08-28-2018, 11:22 AM   #3
1999 35' Cutter Diesel Bus w/slide
Fullerton , California
I posted a few days ago asking the same question and got a few responses. This is exactly what I was looking for. I have a 99 Cutter pusher with the same old TV and would like to upgrade to a flat screen HD TV. We have a big box the the old TV is mounted in and I was wondering if anyone took the box out and fabricated a mount using oak to match the rest of the coach. Would love to see what others have done.
TinPeddler is offline   Reply With Quote
Old 10-14-2018, 01:00 PM   #4
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
New TV Mount
Mike,
Does the new 24" TV block the switch panel on the left and the A/C vent on the right? Also what are you going to do with the bedroom TV? (9", I think)
Paul (Decided to stay with the Land Yacht)
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 03-13-2019, 09:03 PM   #5
Mike1997's Avatar
Images: 14
Sorry I have not checked this post in awhile.
Lford - I will message you direct about photos.
Paul - It does not block the vent on right side, but it can hide the switches on the left side. When traveling I use a bungie cord and Velcro strips so its positioned more to the left in travel mode. Have not done anything to the bedroom TV yet but may do something similar back there. Using a TV with built in DVD also makes a difference.
Old 03-17-2019, 11:04 PM   #6
airstreambob's Avatar
1993 30' Excella
1992 21' Sovereign
2000 30' Excella
2001 31' Land Yacht
Valley Park , Missouri
Just went through this too!
Recently found a gem of a 2001 30' Land Yacht. Both TV's were missing. Ugly hole in the dash. I purchased a piece of plywood, Cut it to overlapping size, Covered it with black padded vinyl with a hole at the bottom for a Blu ray player and used a thin wall mount to put a 24" smart TV up front. Still working on the back solution. Post when you get it figured out, might save me some time! Thanks!
airstreambob is offline   Reply With Quote
Seeking a 19-21 foot project trailer for Food Truck project debbooooo Airstream Classifieds 0 09-06-2016 01:00 PM
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Amarillo Upgrade Package joshua32064 2000 - 2004 Safari 5 09-28-2003 08:14 AM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Rear bed frame upgrade ViewRVs Airstream Motorhome Forums 3 05-10-2003 09:53 PM
