Old 10-11-2020, 09:44 PM   #1
airstreambob's Avatar
1993 30' Excella
1992 21' Sovereign
2000 30' Excella
2001 31' Land Yacht
Valley Park , Missouri
Transmission Gear indicator on 2001 L/Y
Been looking everywhere for the little plastic needle in the steering column that points to the gear engaged. Suddenly mine quit moving and I found that it was broken. First thought was to glue it back together, but I can't find the piece that broke off, all I could find was the upper 75% which includes the white arrow itself, which I can get back into the column, but it will only work with the steering wheel tilted all the way forward as the square shaft is no longer long enough to stay in it's hole.
Anyone else have this issue or know of a fix?
Thanks!
airstreambob is offline   Reply With Quote
Old 10-17-2020, 08:49 AM   #2
2018 25' International
Slidell , Louisiana
Have you tried the used parts on ebay?
Brian
2001 airstream Bambi 19ft in amazing condition :: 2001 Airstream Bambi Matthew24 Airstream Registry Discussions 0 04-15-2019 04:02 PM
Transmission won't shift gear Packerfan316 Land Yacht/Legacy Motorhomes 2 05-18-2011 08:39 PM
"Power On" indicator davidz71 Electrical - Systems, Generators, Batteries & Solar 23 09-15-2005 09:52 AM
Electric indicator Panel Joan D'Andrea Electrical - Systems, Generators, Batteries & Solar 1 11-01-2002 12:03 AM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
