Does the dashboard indicator light light when you turn the directionals on? I ask this to test if the directional switch is getting power.
There are 2 fuses. The stop and hazard fuse and the turn signal. That may be why you hazards work but not the directionals.
I think you are on a Chevy chassis and if so check fuse 16. That should be the directional.
2004 Excursion 4x4
